What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Oct 14, 2015 at 10:38 PM
    Chasin Tail
    Chasin Tail Well-Known Member
    Olympia, WA
    2016 Tacoma DCSB 4x Sport MGM
    some pics with the various lifts on them would be super helpful!
    Little6, Peanut424 and Khisaw like this.
  2. Oct 15, 2015 at 4:17 AM
    TacomaN8
    TacomaN8 Well-Known Member
    Nate
    tbd
    Hypotheticaly speaking, I'd bet if you installed 16 coils on a 15 (all other things being equal), it'd sit higher too. The coil really determines static ride height whereas the shock/struts primary purpose is to control the rebound/ dampening after the spring is compressed. So it's not shocking to read the 16 shock has the same droop but less compression stroke since the coil is likely a higher spring rate and/or longer freelength, thereby providing the 1" lift difference from the factory. It's easy to order new struts to match a stiffer coil. The goal of any suspension design is to have a critically or slightly underdamped system.
    DangerClose and Hiluxski like this.
  3. Oct 15, 2015 at 8:32 AM
    OrangeTexan
    OrangeTexan Well-Known Member
    San Antonio
    2012 4X4 TRD OR
    Don't care about proving something or somebody wrong, I'd just like for them to measure for us off of something other than a feature that has changed, that in all reality, has nothing to do with the amount of lift. Yes, the fender was a nice, convenient reference point, but until we can be sure the reference point didn't change with the new design, it would be nice to have some objective measurements - this in the light of the fact that some have already lifted 3" on a gen3 with no other issues other than what you expect on a gen2 with a 3" lift. That's all I'm saying.
    A quick measurement from Toytec would make it all clear.
    Arailt and DoorDing like this.
  4. Oct 15, 2015 at 8:36 AM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Did you miss the part where they also did a measurement on the lift with suspension at full droop to confirm their findings?
  5. Oct 15, 2015 at 8:42 AM
    hack4875
    hack4875 1 of 377
    Colorado Springs, CO
    2015 TRD PRO Supercharged
    Awesome info. As everyone knows, Toytec rocks. Thanks fellas. :thumbsup:
  6. Oct 15, 2015 at 8:59 AM
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
    As someone who is new to lifting at all, what is a good reference to start to understand how all the pieces work and not get too much contradiction from one post to the next. I always thought lifting was just for clearance but am now realizing it would also improve the ride if done right? Is that true?
  7. Oct 15, 2015 at 1:46 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sounds like the 3rd gens are using a slightly stiffer coil or slightly different stock shock which already has ~ 1/2 difference in spring seat height to get the 1in difference in ride height.
    Thanks for the info toytec.
    Next thing might be to compare spring rates of the 3rd gen to the 2nd.
  8. Oct 15, 2015 at 3:38 PM
    AngelMoroni
    AngelMoroni Well-Known Member
    '16 TRDORDCLB
    Yup
  9. Oct 15, 2015 at 9:43 PM
    Clay
    Clay Well-Known Member
    Clay/K7CR
    Auburn, Wa
    2016 7559 Tacoma
    The comments about lift are very interesting. I run a 3 inch suspension lift on my 2010...Have a confirmed order for a 2016 7559, should get a build date tomorrow. My issue is that I must run chains on the front wheels, to get upper A-Arm clearance I run LT 235/85-16's. Wondering if the clearances are the same on the 2016 in that area? Fatter tires look cool but are no advantage when going up steep hills in snow and ice.
    TacoMan1207, Tocamo and T23 like this.
  10. Oct 15, 2015 at 9:44 PM
    mudcheck
    mudcheck Well-Known Member
    2016 DCLB TRD OR
    Thanks Angel,Can we get somewide angle shots of your truck?
  11. Oct 15, 2015 at 9:47 PM
    mudcheck
    2016 DCLB TRD OR
    Also how does the truck feel to you,I've got the same truck on order in mag grey,my first Tacoma,I was reading another post where the op was saying the truck bounces going down the road on pavement,he also said it was the first truck he ever drove,I think he was smoking crack myself,but whats your opinion,have you given details in another thread?
  12. Oct 15, 2015 at 9:53 PM
    AngelMoroni
    '16 TRDORDCLB
    It rides like a truck with an off-road suspension. If there is a bump in the road you feel it. Seams in concrete that are settled, old highways, you bounce along. New asphalt, smooth ride. Feels similar to my '11 trdor. A lot bumpier than our Subaru outback was. Other review was from a guy who had CUVs and currently a Mazda 3 I think, yeah I'm sure it was bumpy as all hell to him.
    Should be some wider angle shots in the quicksand thread.
  13. Oct 15, 2015 at 9:56 PM
    mudcheck
    2016 DCLB TRD OR
    Thanks again!
    Two Hawks likes this.
  14. Oct 15, 2015 at 9:59 PM
    W00ds3oo
    W00ds3oo Well-Known Member
    Northern California
    16 TRD sport
    great info! I understand that the 3rd gen rides higher, but does it have more tire clearance or do the fenders adjust for that? I had a 13 with a 2" front 1" rear lift with 32.5 tires. Is it safe to say I could run the same set up or would I only need to lift 1" in the front to accommodate the 32.5 tire? thanks for the insight
  15. Oct 16, 2015 at 8:27 AM
    #35
    blens
    blens Well-Known Member
    British Columbia
    Blazing Blue 2016 TRD Sport Upgrade 6MT Tacoma
    My TRD Sport has what I would call a stiff suspension, not bouncy. While you feel all the bumps in the road (stiff), it doesn't bounce (multiple compressions of the suspension after one bump).
  16. Oct 16, 2015 at 8:33 AM
    #36
    TacoTuesday86
    TacoTuesday86 Well-Known Member
    2016 TRD Sport DCSB M/T MGM 4x4
    I ordered a 3" lift and 265/70r17 for my sport. Hoping to avoid any trimming
    Pearcytaco and JPToyotaRacing like this.
  17. Oct 16, 2015 at 8:35 AM
    #37
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    You could fit that size on stock.
    Bobcat Luke and NorCal3056 like this.
  18. Oct 16, 2015 at 8:39 AM
    #38
    TacoTuesday86
    So I should of gone with 285's :facepalm:
    C3292, Jukeboxx13, MaxxTRD and 2 others like this.
  19. Oct 16, 2015 at 8:40 AM
    #39
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Yes.
    MaxxTRD and K Mac like this.
  20. Oct 16, 2015 at 8:42 AM
    #40
    TacoTuesday86
    I just changed my order.... 285/70r17
