What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Dec 30, 2015 at 2:30 PM
    #641
    TacoMEDIC
    TacoMEDIC Well-Known Member
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    I have no idea. I don't have them yet, but I'd imagine each set up will be different depending on suspension set up, settings, wheel size and offset and tire height and width.
    Still looking for advice on my proposed set up.
  2. Dec 30, 2015 at 9:02 PM
    #642
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    itll also come down to your alignment numbers. 0 camber. 3.0-3.2 castor. 0.01-0.05 toe will be best. im not rubbing at all with my current set up. if they set castor based on stock range youll rub body mount side.
    Tacoma2GR likes this.
  3. Dec 30, 2015 at 10:51 PM
    #643
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    This is best for a 2.5 to 3 inch lift?
    I have about a 2.7 lift with 285/70's
    I rub on the right side
  4. Dec 31, 2015 at 5:51 AM
    #644
    pngo121
    Phi
    Pittsburg, CA
    Are you rubbing on the cab mount side?
  5. Dec 31, 2015 at 6:10 AM
    #645
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Still hoping for some advice here...
  6. Dec 31, 2015 at 6:52 AM
    #646
    pngo121
    Phi
    Pittsburg, CA
    I am getting pretty close to pulling the trigger on a lift/suspension set up. Need some advice. I am likely buying the following:
    King 2.5 Remote Resi Coilover (25001-119)
    Total Chaos Uniball UCA (96504)
    King 2.5 Remote Resi Rear Shocks (25001-121)
    Icon Add a Leaf (51100) Or Deaver Add a Leaf
    Method NV 17 x 8.5
    BFG KO2 285/70/17
    Am I missing anything?
    should be golden with that setup.
    Should this be level? Or close? Don't want rake and really don't want to be nose up either.
    Your stance is dependent on how you set your front coilovers. They're adjustable so you can set as pleased.
    Do I also need spacers in the front to clear 285/70/17s? No
    Do I need a spacer to correct the Taco Lean? No. All you would need to do is set your preload higher on the driver side. My coilovers are 5/16" difference and it levels out the front perfectly.
    If I go with Deaver add a leaf (or either really) do I need the shim? Or do I need anything else to correct the geometry?
    For the Leaf pack, if you want to save some money you can go with the toytec progression or the wheelers multi progressive pack.
    There hasn't been any reports of vibrations after lift so you wouldnt need the ship or cb spacers. I added the shims on my truck just because the kit I bought came with it.
    For alignment after its all installed.
    camber: 0 (very important for tire wear)
    castor: 3.0-3.2 (this will bring your tire more forward to avoid rubbing cab mount with stock range)
    toe: 0.01-0.05
    TacoMEDIC[QUOTED] and 0uTkAsT like this.
  7. Dec 31, 2015 at 7:00 AM
    #647
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Thank you!
  8. Dec 31, 2015 at 7:07 AM
    #648
    pngo121
    Phi
    Pittsburg, CA
    With the progression packs, I would suggest taking them apart and putting another coat or two of paint on them. I had mine on for only two months and they are completely covered in rust already. I drive up to the snow every weekend though.
    TacoMEDIC[QUOTED] likes this.
  9. Dec 31, 2015 at 7:13 AM
    #649
    pngo121
    Phi
    Pittsburg, CA
    One other thing in regards to the preload setting on the coilovers. You can set them as pleased but there is a maximum. I'm not exactly sure with the numbers are on the Kings. Double check with King or where you purchase them.
  10. Dec 31, 2015 at 8:29 AM
    #650
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Thanks. I have some experience with shocks from racing offroad. I admit there were guys on my team who knew a lot more about it and did most of the suspension setup, but I learned enough to figure it out. That said, I will be contacting King if for nothing else, having peace of mind.
  11. Dec 31, 2015 at 8:31 AM
    #651
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    BTW... Trigger pulled. Everything listed is on the way!
    ĂśberToyota, MaxxTRD and Tacoma2GR like this.
  12. Dec 31, 2015 at 8:34 AM
    #652
    pngo121
    Phi
    Pittsburg, CA
    nice!
  13. Dec 31, 2015 at 9:36 AM
    #653
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I'm excited to see how this comes out, I'm sure it'll look sweet. Let me know when you get your parts in, maybe we can meet somewhere local and check it each other's trucks.
  14. Dec 31, 2015 at 9:41 AM
    #654
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Absolutely.
  15. Dec 31, 2015 at 10:05 AM
    #655
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Actually, there have been reports of the needle bearing vibe.
  16. Dec 31, 2015 at 10:08 AM
    #656
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I rub on my right side, on the cab mount and a little on the fender corner.
    I defitenely need another alignment.
    After I lifted the the truck my alignment tech said he didn't have to touch the right side because it was still in spec and he only had to adjust the left side.
    Maybe that's why it's rubbing.
  17. Dec 31, 2015 at 10:51 AM
    #657
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Where did you go? I have a friend in Hesperia that owns an auto shop. I'm sure he'd do a good job, but I'd rather go somewhere where the techs had specific experience in aligning vehicles aftermarket setups i.e. Extended travel shocks/ aftermarket UCA
  18. Dec 31, 2015 at 10:57 AM
    #658
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I had it done at auto shop in Barstow,
    I was out that way for work and figured a local shop there could get an alignment right.
    I'll be going back though since I paid for it already. They should offer free adjustments. My left side seems to be golden.
  19. Jan 1, 2016 at 7:54 AM
    #659
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
    What brand/model tires are these? I wasn't able to find that size anywhere.
  20. Jan 1, 2016 at 8:14 AM
    #660
    PJC1183
    PJC1183 Well-Known Member
    Ontario, California
    2017 Cement TRD Pro
