What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Jan 3, 2016 at 6:43 PM
    #701
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    Lol! Good talk! I just read a post by toytec saying that you can get away with stacking your 1/4 top plate spacer with a 1/2 top plate spacer. But maybe ill just set the billys at .85 and be done. Thanks for your post.
  2. Jan 3, 2016 at 8:59 PM
    #702
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    Yeah then you probably need the longer studs up the top. I was going to do that initially but this is a good way too. You could always just try 887a at 0 and see what you get.
  3. Jan 3, 2016 at 9:13 PM
    #703
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Where did you buy the kit from?
  4. Jan 4, 2016 at 5:33 AM
    #704
    twogiraffe
    twogiraffe Well-Known Member
    Las Vegas, NV
    2016 Double Cab Longbed Offroad Inferno
    * AllPro LOLA 2.0 with expedition rear leaf springs * Stealth Custom Series F5. 17x8.5 Gunmetal * BFGoodrich TA KO2 285/70/17 * SnugTop XtraVision
    AZInferno likes this.
  5. Jan 4, 2016 at 10:56 AM
    #705
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    So I'm ordering my lift this week. 5100s, 885s 1/4 spacer, and an aal. Just not sure if I want a wheelers or Toytec or deaver AAL. can anyone chim in. I'll be running the 5100s at 0 for now
  6. Jan 4, 2016 at 11:01 AM
    #706
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Which AAL did you go with? And is that a full ome schocks also
  7. Jan 4, 2016 at 12:42 PM
    #707
    dontstealmyride
    dontstealmyride Well-Known Member
    SLC, UT
    2016 TRD sport MGM sortbed
    A lot of members on this Forum went with this kit.
    PJC1183 in another thread said he went with this kit on his truck. I have the same thing on order.
    https://bilsteinlifts.com/shop/toyota-tacoma/2005-2015/ome-suspension-lift-kit/
  8. Jan 4, 2016 at 12:43 PM
    #708
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
  9. Jan 4, 2016 at 4:10 PM
    #709
    TacoMEDIC
    TacoMEDIC Well-Known Member
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    After speaking with King this morning, I decided to cancel my order on the kings and go with the extended travel version of the same shocks: 25001-119E and 25001-121E. If anyone is wondering, the extended travel versions designated with "E" at the end of the item number are 1/4" longer than the non-"E" version. They are not in the King catalog and are considered a custom shock, but they are regularly produced and sold. Per King, aftermarket UCA is required to run these shocks in the front.
    Tacoma2GR likes this.
  10. Jan 4, 2016 at 7:39 PM
    #710
    mr2r6
    mr2r6 Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    Would that mean 1/4 more lift?
  11. Jan 4, 2016 at 7:50 PM
    #711
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    As I understand it, the main benefit isn't that you get more lift, but you get the same lift with slightly more down travel (droop).
    mr2r6[QUOTED] likes this.
  12. Jan 4, 2016 at 8:04 PM
    #712
    Tacogram
    Tacogram Well-Known Member
    Apple Valley. CA
    Yes. Almost 1" of extra down travel with aftermarket UCA's
    TacoMEDIC[QUOTED] likes this.
  13. Jan 4, 2016 at 10:21 PM
    #713
    AWDbacon
    AWDbacon Member
    2016 white sport taco with jbl
    5100's .85, OME 887, FN BFD 18x9, BGF Ko2's 285/65/18
    So when running this setup is it necessary to order the Front Diff Drop and the Carrier Bearing Drop Kit?
  14. Jan 5, 2016 at 6:08 AM
    #714
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Diff drop only on 4x4
  15. Jan 5, 2016 at 6:32 AM
    #715
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    How much wheel travel does an additional 1" of shock droop (or lift) translate to?
  16. Jan 5, 2016 at 6:33 AM
    #716
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Those of you doing aftermarket UCA's, how many had to cut off the UCA bolts and replace with new bolts? Did you have to cut both sides? Want to know so I can order them and have them ready when my truck finally arrives.
    ScottyR likes this.
  17. Jan 5, 2016 at 7:35 AM
    #717
    2016TacomaDCLB
    2016TacomaDCLB Active Member
    2016 DCSB TRD Off-Road
    This is the kit I am thinking about ordering as well. My concern is length of the shocks. Because of the "extra inch" of lift you get from the '16 Tacoma, will these shocks be too far extended?
  18. Jan 5, 2016 at 7:54 AM
    #718
    2016TacomaDCLB
    Is it still riding well after settling? I'm fairly certain I'm going with this same lift. Did you use the 1/4" top spacers on either side?
  19. Jan 5, 2016 at 8:07 AM
    #719
    sandyTrd87
    sandyTrd87 Well-Known Member
    Socal
    Bilstien 5100's x4 Dobinson 448 springs, rear 2inch AAL
    offgasing2 and rodeho like this.
  20. Jan 5, 2016 at 8:09 AM
    #720
    \000/
    \000/ Well-Known Member
    Waimanalo, HI
    2016 DCSB 4x4 TRD Sport
    Yup rides great! Did the trim packer (1/4" spacer for driver side lean) but that's all.
    ridez and 2016TacomaDCLB like this.
