What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Jan 5, 2016 at 8:12 AM
    #721
    sandyTrd87
    sandyTrd87 Well-Known Member
    Socal
    Bilstien 5100's x4 Dobinson 448 springs, rear 2inch AAL
    I really like your truck man!
    \000/[QUOTED] and ridez like this.
  2. Jan 5, 2016 at 8:18 AM
    #722
    2016TacomaDCLB
    2016TacomaDCLB Active Member
    2016 DCSB TRD Off-Road
    Best looking '16 Sport I have seen yet.
    \000/ likes this.
  3. Jan 5, 2016 at 8:36 AM
    #723
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    Had to cut passenger side out.
    Toynado[QUOTED] likes this.
  4. Jan 5, 2016 at 9:16 AM
    #724
    JerryTaco
    JerryTaco Well-Known Member
    If you are replacing the UCA's, the passenger side will definitely have to be cut, unless you lift the body from the frame. That said, only the passenger side has to be cut so you'll only need to order one bolt from Toyota. The process of actually cutting the bolt is very easy and fast.
    ridez and Toynado[QUOTED] like this.
  5. Jan 5, 2016 at 11:31 AM
    #725
    TacoMEDIC
    TacoMEDIC Well-Known Member
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    I planned on cutting at least one. Haven't contacted Toyota to order the part yet, but I'll order 2 just in case. Those that have done this, did you order through Toyota or somewhere else? How long did it take? Link if purchased elsewhere?
  6. Jan 5, 2016 at 11:42 AM
    #726
    JerryTaco
    I got mine directly from my dealerships parts department. It's such a long bolt, I dont know where else you'd find it except for maybe RockAuto? Anyhow, only took a few days to get it in.
  7. Jan 5, 2016 at 11:50 AM
    #727
    mr2r6
    mr2r6 Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    Someone correct me if I'm wrong, but the extra inch on the 16s comes from stiffer factory springs which will translate to only 2" of lift when using the same lift that would get 3" on the 2nd gen.
  8. Jan 5, 2016 at 12:06 PM
    #728
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Thanks. Happen to have a part number?
  9. Jan 5, 2016 at 12:07 PM
    #729
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    Correct
  10. Jan 5, 2016 at 12:44 PM
    #730
    rodeho
    rodeho Well-Known Member
    Rob
    Pensacola
  11. Jan 5, 2016 at 12:46 PM
    #731
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
  12. Jan 5, 2016 at 12:57 PM
    #732
    rodeho
    Rob
    Pensacola
    You are welcome!
  13. Jan 5, 2016 at 1:02 PM
    #733
    JKL808
    JKL808 Active Member
    2016 DCSBTRDSPMT4X4PTBBP
    I was able to get both UCA bolts out without cutting them. Yes, the passenger side is a lot tighter but doable you just gotta bend a little more of the fender. I used a pair of sheet metal vice grips to bend (and unbend) the inner fender, and at the same time used a long 3/8 socket extension to tap the bolt out. Would it be easier to just order new bolts? maybe, just thought I would share my experience.
    nevadabugle and Toynado[QUOTED] like this.
  14. Jan 5, 2016 at 1:09 PM
    #734
    JerryTaco
    Damn, you must of had to bend the shit out of the passenger side to get that bolt out.. That's what I tried first, however after seeing how much I was going to have to bend, I just opted to cut and replace the bolt.
    Toynado likes this.
  15. Jan 5, 2016 at 1:20 PM
    #735
    JKL808
    Yup. Though you can barely tell it was ever bent especially once those rubber guard things are put back on.
  16. Jan 5, 2016 at 4:01 PM
    #736
    \000/
    \000/ Well-Known Member
    Waimanalo, HI
    2016 DCSB 4x4 TRD Sport
    Thanks guys!
  17. Jan 5, 2016 at 4:02 PM
    #737
    Tacogram
    Tacogram Well-Known Member
    Apple Valley. CA
    I'm saying you get 1" of down travel (wheel droop as you say it)
  18. Jan 5, 2016 at 4:27 PM
    #738
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    Right, but where is that 1" measured? At the shock? At the wheel? I'm new to off-roading, but can't imagine one extra inch of down travel is worth much of anything, and certainly not worth paying for. Or am I wrong?
  19. Jan 5, 2016 at 4:50 PM
    #739
    Tacogram
    Apple Valley. CA
    The uca, lca, wheel travels down 1" more. And yes that is quite a bit.
    It's called suspension travel because all of the suspension components travel up or down. So 1" of down travel is just 1" of down travel. Not sure how else to explain it
  20. Jan 5, 2016 at 6:06 PM
    #740
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    I saw a post on here with the part number and found them on Amazon & EBay: part #90105A0095
    ScottyR and TacoMEDIC[QUOTED] like this.
