What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Feb 19, 2016 at 2:27 PM
    #1321
    louie7497
    louie7497 Well-Known Member
    Louie
    Las Vegas
    2016 TRD Off Road
    I think i successfully made a "build page". Take a look if you're interested. https://www.tacomaworld.com/threads/louies-build-2016-trd-off-road-double-cab.417631/
    It will rub. Period. That's what i have and in some off road situations i rub. ON street i have yet to rub.
    Toytec boss 2.0 TC UCA AAl 285/70/17
    Rubs.
    no body lift, so spacers.
  2. Feb 19, 2016 at 2:35 PM
    #1322
    Pportera
    Pportera Well-Known Member
    3rd gen.
    So basicly strut spacers with stock '16 coils are suspension suicide! Lol. Obviously one should avoid such said "spacer" lifts.... How about bilstein 5100 adjustable with stock coils?
  3. Feb 19, 2016 at 2:44 PM
    #1323
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Key thing is to stay at the 23 mark. The Bilsteins are not ideally valved for the springs on the 16's so i can't specifically recommend them. However many many people in this thread have used them with success.
  4. Feb 19, 2016 at 3:07 PM
    #1324
    TWTaco
    TWTaco Well-Known Member
    Dave
    Ok so if i get a Icon stage3 with UCR and run a 285/75/17 i may have some slight rubbing and make sure not to go more 1.5 threads on coil adjustment i will be good to go????? Or more then 23 inch from center hub to fender lip correct?????
  5. Feb 19, 2016 at 3:50 PM
    #1325
    Toytec Lifts
    Rocky Mountains
    I do recommend to stay at or below that 23" hub to fender mark but you might want to ask ICON as well as to what they recommend
  6. Feb 19, 2016 at 6:25 PM
    #1326
    Wdwrkr
    Wdwrkr Well-Known Member
    Pete
    Nantucket MA
    2016 TRD Off-road DCSB
    None :-((. Yet :-))
    So would adding the 1" body lift to the Boss kit reduce the rubbing or am thinking about this wrong. Also am I looking for trouble doing this
  7. Feb 19, 2016 at 6:28 PM
    #1327
    Wdwrkr
    Pete
    Nantucket MA
    None :-((. Yet :-))
    Thanks, not the answer I was hoping for, but honesty counts
  8. Feb 19, 2016 at 6:33 PM
    #1328
    CDPlaya
    CDPlaya Well-Known Member
    CD
    New Awlins Who Dat?
    Newbie
    None
    Is the rub coming from the width 285 or the tire height 70 ?
  9. Feb 19, 2016 at 6:42 PM
    #1329
    Wdwrkr
    Pete
    Nantucket MA
    None :-((. Yet :-))
    I wonder the same thing. In a perfect world I'd like to move the tires out bound an inch or so, but I think that would exasperate the problem
  10. Feb 19, 2016 at 6:56 PM
    #1330
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    If your in it for a better ride I would put the 5100s in rear as well. Overall found the truck less bouncy and more planted with them on all four corners.
  11. Feb 19, 2016 at 7:04 PM
    #1331
    stealthmode
    Alberta
    Hmmmm.... makes me want to wait before pulling trigger then on my 5100s front. Good deal right now at 175 ea CAD to my door though.
    If I had to guess- they're at least 1 year out for the proper R&D and production for the 2016' part numbers?! o_Ous OCD modders can't wait that long!
  12. Feb 19, 2016 at 7:46 PM
    #1332
    Woody79
    Woody79 Well-Known Member
    Kevin
    Utah
    2016 DCSBOR 4x4 Quicksand
    Icon Stage 2 TRD Pro Wheels 285/70/17 BFG KO2's Header Rail Extang Solid Fold 2.0 Tonneau Cover
    For what it's worth, I have an Icon Stage 2 installed (still running factory UCA's at this point). I started originally with my coils adjusted to 1.5" of thread showing but bumped them up to 1.75" of thread after a few weeks to compensate for settling and the fact that I left the factory overload leaf in rear for towing/hauling which propped up the rear a bit more than most. I have 285's and am not even close to rubbing, over an inch to the cab mount. Didn't rub at 1.5" of thread either. I think a lot of it has to do with the 7" rims I'm running and the lack of a lot of offset, etc. May get UCA's in the future but the dealer was able to align it just fine as is. I'm about 23.5" hub to fender in the front. More details in my build thread (link in signature).
    NV_Tacoma likes this.
  13. Feb 19, 2016 at 11:28 PM
    #1333
    619HiluxLover
    619HiluxLover Well-Known Member
    2016 Magnetic Gray TRD Sport Double Cab
    5100s all around, Spidertrax spacers, Deaver 3 Leaf Mini Pack, NFab Nerf Bars, 285/70/17 KO2s
    Noob here and total rook to all this, so I apologize lol. Can someone please explain how to measure the difference between the front and rear tires/wheels, etc? I've been told it's a couple or so inches difference, but I wanna know where exactly I measure to and from. Thanks for any info and educating me!
  14. Feb 20, 2016 at 8:50 AM
    #1334
    WCoyne
    WCoyne Well-Known Member
    EastTN
    2016 F150 Platinum Fx4
    Fuel Nutz blacked with milled 2 piece wheels, 285/65/20 BFG KO2 tires, Icon Stage2
    At what amount of front lift do you need UCA's? I had 2" on my 2006 and was fine without replacing the upper but remembered people saying anymore and I would need to get them
  15. Feb 20, 2016 at 9:30 AM
    #1335
    Pportera
    3rd gen.
    On flat level surface measure from center of fender lip down to center of hub/wheel.
    My drivers side is 1/4" lower then passenger side.
    619HiluxLover[QUOTED] likes this.
  16. Feb 20, 2016 at 11:30 AM
    #1336
    619HiluxLover
    Thanks brother!
  17. Feb 20, 2016 at 2:21 PM
    #1337
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
  18. Feb 20, 2016 at 2:55 PM
    #1338
    Pportera
    3rd gen.
  19. Feb 20, 2016 at 6:07 PM
    #1339
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I've been looking at them too....i wish someone knew. Looks like a china version of the TC's, but if they work i'm ok with that.
  20. Feb 20, 2016 at 6:17 PM
    #1340
    louie7497
    Louie
    Las Vegas
    2016 TRD Off Road
    I just spent some time on the trail. I really like this suspension. Didn't rub at all today. You may be ok.
