What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Mar 29, 2016 at 2:26 PM
    #1801
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    He did not mention the alignment. I will call back to get the answer. I agree that price should include the alignment.
  2. Mar 29, 2016 at 2:44 PM
    #1802
    mrproduxn
    steve
    Retired DoD SE VA
    Just talked to 4wheelparts in Va Beach. 5100's $189. Labor $360. Alignment $117. That is roughly $670 for an added 1" of lift in the front. Maybe I will just go with 17" x 8" wheels and spacers for the same money.
  3. Mar 29, 2016 at 2:48 PM
    #1803
    JerryTaco
    JerryTaco Well-Known Member
    or if you are remotely handy, you could do the install yourself. It's actually super easy and can easily be accomplished with basic hand tools.. Will still need an alignment though.
  4. Mar 29, 2016 at 2:50 PM
    #1804
    mrproduxn
    steve
    Retired DoD SE VA
    Don't you need a spring compressor for this job. I am handy and have a garage full of tools. Just would prefer having install done at shop that can align it too. But not at nearly $700. Just never messed with struts. Have done nearly everything else to vehicles.
  5. Mar 29, 2016 at 2:52 PM
    #1805
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    the AAL is the biggest pain to install. EDIT: that is if you buy a kit with the coils pre installed on the shock. I have swapped my coil overs out twice now, the 2nd time was by myself and only took about 2 hours, my drivers side lower shock bolt was seized so i had to get crafty :D
  6. Mar 29, 2016 at 2:52 PM
    #1806
    JerryTaco
    Yeah, you will need a spring compressor, which you can rent if need be. When I do these installs, I usually just take the factory shocks to a local shop near me, and they charge me 50 bucks to do the coil swap.
  7. Mar 29, 2016 at 3:15 PM
    #1807
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    I used the method that Josh showed me which involved using a floor jack to decompress the spring with the lower control arm which was much safer than trying to use a spring compressor. You can find a lot of videos on here of doing it that way and then you just have to pay for the alignment.
    0uTkAsT likes this.
  8. Mar 29, 2016 at 3:18 PM
    #1808
    mrproduxn
    steve
    Retired DoD SE VA
    Thanks for the input. In no rush. Money is not really an issue but don't think the gain is worth the investment at this time. Biggest thing is I do not like the stock rims and would like meatier tires. Gonna get some local install quotes. Then will decide. Remember this is a 2 wheel drive truck so not looking for major geometry changes like ucl's and stuff. I can get the top level plates installed for a mere $100 but just wanted the potential adjustability of 5100's. Wheels are the last important mod to me. It's like an itch that I can't scratch. I say last mod but that is until I decide on head and fog lights. Don't want to go crazy until factory warranty is up.
  9. Mar 29, 2016 at 4:11 PM
    #1809
    xTacoma16x
    xTacoma16x Well-Known Member
    TRD sport 2016
    You don't need spring compressor, if you have hydrolic one I would use it if not don't bother with conventional ones it will take too much time.
    It is super easy to do it your self if you have tools and place, I've done at least 4 times this way with longer than stock coils. When you know how it's done, it takes literally 30min per side.
    Look at this video how to
    https://m.youtube.com/watch?v=5E6u7dC7EHg
    https://m.youtube.com/watch?v=jo0FJSi-KYs
    ĂśberToyota, Ronin229 and 0uTkAsT like this.
  10. Mar 30, 2016 at 8:02 AM
    #1810
    GuitarGuy91
    GuitarGuy91 Well-Known Member
    Stephen
    Glenville, NY
    16 TRD OffRoad Acc Cab (ordered)
    So I ordered the Bilstein Adjustable Lift kit from Toytec, with the springs pre-mounted and set to the first clip which they say is 1.5" lift. Aal for the rear.
    Now I'm starting to wonder if this lift set-up will work for my 2016 access cab. I want about 2" of lift altogether, and putting 265/75/16 tires on. Would it have been a better idea to go with OME kit for what I want? I can still call and change my order...
    EDIT: I went ahead and changed my order to the OME kit. Went with 90021 shocks, 885 coils, and Dakar leaf pack. I think the leaf pack will be great for heavier loads.
    619HiluxLover likes this.
  11. Mar 30, 2016 at 8:48 AM
    #1811
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    I did a lot with the inch and half block. Dropped it down to a single inch and it's not so bad. But yes it does the rear does hop a little in the back when going up ramps fast.
  12. Mar 30, 2016 at 5:19 PM
    #1812
    sullcat
    sullcat Member
    2016 Access Cab Trd Off Road
    First time posting, been lurking for a while. I have a 2016 access cab trd off road, my first Toyota!
    I have an allpro bed rack, tepui kukenam xl rugadized, and I carry a small bar-b-q, 20lb propane bottle, a couple folding chairs, a small chain saw, 5 gallons of water, axe, small folding table, etc. At times I will have my dirtbike on a carrier on the hitch from time to time. I know I'm getting heavy. Does anyone have any suggestions on a lift that will help with my xtra weight? I've read threads and have talked with my dealer. They say OME 886 with dakars, or allpro "pro" lift kit, which I'm expecting includes expedition springs. With the allpro lift I would get u-bolt flip, uca's and extended shocks and longer brake lines, timbren bump stops. There is a difference in price, but I feel I'm getting more in the allpro kit.
    Any feedback would be greatly appreciated. Thanks.
  13. Mar 31, 2016 at 6:12 AM
    #1813
    HARLEY410
    HARLEY410 Active Member
    Darren
    Anyone have any information on lifting a TRD Offroad 2WD about 3"? I hear just doing a spacer lift will be way less expensive such as the rough country 3" kit they offer. Or should I do a more expensive reservoir coil system for a better ride? I also cant find many options for my truck. Please any information or links or threads would be awesome!! Thank you!
  14. Mar 31, 2016 at 6:53 AM
    #1814
    MrSmithsTaco
    MrSmithsTaco Well-Known Member
    Oklahoma City, OK
    2016 Super White Tacoma TRD OR
    Me in the driver seat.
    I didn't know they made an Off-Road that wasn't 4x4. I'm just curious, what does the headliner console look like? The 4x4 is crowded with MTS and Crawl/locker.
  15. Mar 31, 2016 at 7:17 AM
    #1815
    HARLEY410
    Darren
    Yes, they make a 2WD in offroad. I have the electronic package and so I have a sunroof. I live in South Florida, so not much need for a 4x4. The only thing I have is your typical lights and a sunglass holder up top.
  16. Mar 31, 2016 at 8:37 AM
    #1816
    MrSmithsTaco
    Oklahoma City, OK
    Interesting. Thanks. You don't have any swamps or beaches to tear up?
  17. Mar 31, 2016 at 2:21 PM
    #1817
    HARLEY410
    Darren
    No I don't actually. I mean if I go to the MX track there is some dirt there or if youre a construction worker you have sites to mess in, but South Florida is pretty un offroad if you know what I mean. sucks, but I still love my trucks. Wish I lived up north where I would need a 4x4 and do some sand duning somewhere, but oh well. Hope you have an awesome day man!
  18. Mar 31, 2016 at 5:25 PM
    #1818
    MrSmithsTaco
    Oklahoma City, OK
    That's unfortunate. Sounds like it's time for a road trip! As far as 4x4, I've only gone a few places in my life that couldn't have been reached without it. It's all about tires and the driver. Same to you buddy.
  19. Mar 31, 2016 at 6:17 PM
    #1819
    nopinch
    nopinch Active Member
    Broken Arrow , Ok
    I had originally planned on 5100s, 887s, & Camburg uniball UCAs but after seeing these pics I'm kind worried. I was going to opt for the diff drop but even then, the outer tie rod looks pissed and doesn't look like much droop between the uca and the coil itself. I DO plan on off roading and I want the lift but I also want some sort of peace of mind while I'm on the trail miles from no where.
  20. Mar 31, 2016 at 6:23 PM
    #1820
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    The good news is you don't need 4"s of lift. Stick with a 2" lift coilover from Toytec that's adjustable and you will have all you need.
