What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Dec 1, 2015 at 10:55 AM
    #361
    3rdGenConvert
    3rdGenConvert Member
    looks like your shock needs adjusted.
  2. Dec 1, 2015 at 5:25 PM
    #362
    honey
    honey Well-Known Member
    Jeff
    Wisconsin
    16 tdr sport inferno 4x4
    leather, T.C. 6", King coilovers, TC uca's, Alcan, amp, Pro comp, bushwaker, bamf, magnaflow, afe.
    That's a good question, I wish I could answer it for you! Yikes!
  3. Dec 1, 2015 at 5:31 PM
    #363
    honey
    Jeff
    Wisconsin
    Speaking of coilovers and droop, I ordered the King coilovers to go with the 6" lift that I haven't decided on yet. Problem is they won't make them till I give them a measurement. So I think I need the measurement at full droop plus 6 inches. Anyone know if that is right, and what it would be?
  4. Dec 1, 2015 at 7:48 PM
    #364
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
  5. Dec 1, 2015 at 8:13 PM
    #365
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    They should. Plenty of people on here doing 265's with no lift. I will be doing similar - Guardians instead of Tracker (tough choice) - but with 3" Boss lift and 285 BFG KO2's.
  6. Dec 1, 2015 at 8:47 PM
    #366
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    Thanks. I have 2" spacers up front and 18" rims. Think I like a smaller set up. The 33" Toyos really fill up the wheel well. Too much so.
  7. Dec 3, 2015 at 6:27 PM
    #367
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    I put the toytec diff drop on my 2016 DCSB 4x4 with the OME 3" lift and rear AAL and it created some vibration issues that were outrageous sounded like some rubbing and stuff. Took the diff drop kit out and viola noise and craziness gone. Just my experience with the diff drop and OME setup though.
  8. Dec 3, 2015 at 6:41 PM
    #368
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Did you use the wedge shim with your rear leafs?
    Or does that leaf kit different?
  9. Dec 3, 2015 at 6:43 PM
    #369
    proven21
    It was the Wheelers AAL 1.5" I believe and I am unsure if my buddy used any wedge shims I didnt put on the AAL.
  10. Dec 3, 2015 at 6:50 PM
    #370
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Oh okay just asking
    I installed the add a leafs from toytec (Deaver) and I used the wedge. My rear sits a little higher than my front.
    I'll be taking the wedge off this weekend in hopes of leveling out the truck.
  11. Dec 3, 2015 at 6:51 PM
    #371
    proven21
    Yea I am surprised at how level mine is little to no rake at all i know the helper was pulled out and that rear progressive AAL from wheelers worked great with the OME I love the stance now Im just waiting on these damn wheels and tires to arrive.
    tsub345 and Tacoma2GR[QUOTED] like this.
  12. Dec 3, 2015 at 7:10 PM
    #372
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Has anyone here used the 1.5-2 inch add a leafs from toytec?
    Was the wedge used? 4x4 or 2wd
    Mine is 2wd
  13. Dec 3, 2015 at 7:24 PM
    #373
    honey
    Jeff
    Wisconsin
    In case anyone else wants to order custom coilovers from King, I found out the dimension is 22 and about three eighths of an inch, that is the full droop of the factory coilover.. Then if you add the exact heighth of the spacer you will be replacing which in my case is five and three quarters to that measurement. That's how they get the size to make the coilover to eliminate the spacer! So I went with 28 1/4" cstom coilover from King shock.
  14. Dec 3, 2015 at 7:29 PM
    #374
    leduc4wd
    leduc4wd Well-Known Member
    Derek
    Kansas
    ‘23 DCSB TRD Off-Road / ‘17 Pro 4Runner
    Hey guys currently I have 5100's set at 1.75 which gave me 2 1/4" of lift with the eibach coils. Rear is the tac-al 2" lift that gave me 1". Ended up 1/4" lower in front. The new 16' is on its way and I'm wanting this same kind of stance. What I "think" with the 16' using these shocks set at 1.75 and same rear lift it would have the bro lean right? Since the 16' is already a inch taller in front? I'm definitely open to a different/better lift to achieve this. (Sorry if this is stupid)
  15. Dec 3, 2015 at 7:44 PM
    #375
    Tacogram
    Tacogram Well-Known Member
    Apple Valley. CA
    Sounds like you're on the right track. What's the second setting on 5100s? .85? If so then that should give you about the same stance if you did the same leaf in the rear
  16. Dec 3, 2015 at 10:03 PM
    #376
    azlyle
    azlyle Well-Known Member
    Lyle
    Tempe, AZ
    2016 Tacoma Double Cab TRD Offroad 4x4
    3" Toytec lift with UCAs and AAL, Goodyear Duratrac 285/75r16 on 16x8.5 MB Wheels, RPMFAB steel rock sliders, RCI aluminum skids, Pelfreybilt Aluminum Winch Bumper with Smittybilt X2O winch, Yaesu FT-8800R dual band ham radio, Mobilnkd bluetooth TNC for APRS
    Yes, I used the 1.5 - 2" AAL from ToyTec and the wedge shim on my 2016 DCSB TRD OR 4x4.
  17. Dec 4, 2015 at 4:57 AM
    #377
    leduc4wd
    Derek
    Kansas
    Ya its .85. I'm gonna call toytec today and see what they have to say
  18. Dec 4, 2015 at 6:45 AM
    #378
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    What did you use to lift the front?
    Did your truck come out level or did the rear sit a tad bit higher?
    Mine looks just tad higher in the rear, almost like stock.
    I used the 5100 coilover kit 3 inch lift from toytec but since it was set up for the 2015 it looks like I only got about a 2 inch lift on my 16.
    So a 2 inch in the rear and 2 inch in the front it pretty much left me where I started as far as the rake goes.
    But I'll be removing my rear wedges tonoght or tomorrow and hope the rear drops a bit.
  19. Dec 4, 2015 at 8:26 AM
    #379
    dmac808
    dmac808 New Member
    2015 BDS kit
  20. Dec 4, 2015 at 1:42 PM
    #380
    azlyle
    Lyle
    Tempe, AZ
    The boss 3" lift adjustable front with SPA upper control arms. At the preset height on the coils, the rear is just slightly higher up, pretty much the same angle as stock. I'll eventually crank up the front another 1/2 inch or so when I put on bigger tires, but I'm happy with it for now.
