Whatever
Where Should World2405 Go After Retiring from the Army?
  1. JAPAN and Live Out His JDM Fanboy Fantasy with a R32GTR
    40.0%
  2. ARIZONA and Live the Outdoorsman Life
    60.0%
  1. Aug 6, 2020 at 5:02 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    I promise, once ya go crossbow, ya wont want a compound, not that there is anything wrong with compounds, but a crossbow just hits so hard, and is so accurate..... :notsure:
  2. Aug 6, 2020 at 5:38 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Good Morning Everyone
  3. Aug 6, 2020 at 6:00 AM
    ReefSR54X4
    ReefSR54X4 JerzeeBwah
    Jersey
    2016 BB AC SR5
    that boy sure can play!! Awesome!!!
  4. Aug 6, 2020 at 6:02 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Help me solve this mystery!
    So ever now and then I'll wake up to a small puddle in the middle of the bathroom floor. I've not been able to identify the source, no water trail to toilet or other water sources in the bathroom or water damaged looking areas on the walls or ceiling. Just a puddle right in the middle of the floor usually about 10" in diameter and a quick clean up! I'm not getting drunk and missing the toilet in the middle of the night that'd produce a much larger puddle!!
    So far my thoughts are:
    1. A crack in the slab maybe, and coming up through vinyl flooring. I need to pay more attention to if it only happens when its raining!
    2. Humidity causing the pooling, it is SC!
  5. Aug 6, 2020 at 6:14 AM
    Gritto
    Nowhere Else, Pottsylvania
    2006 AC AT V6 PreRunner
    Stock. SR5 Package #2.
    Can't like. :mad:
    FishnTx and 1buzzbait like this.
  6. Aug 6, 2020 at 6:18 AM
    Gritto
    3.
    .jpg
  7. Aug 6, 2020 at 6:22 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Doors shut though, thought about that, but its even happened before his arrival to the house!
  8. Aug 6, 2020 at 6:28 AM
    Gritto
    FishnTx, Taco critter and 1buzzbait like this.
  9. Aug 6, 2020 at 6:29 AM
    OneGiraffe
    OneGiraffe The cake is a lie
    Tiffany
    NW MT
    '17 Tundra TRD Off-road & '15 DCLB TRD
    Are you taking a shower at night? Have you looked up at the ceiling and touched it to make sure nothing is coming from above?
  10. Aug 6, 2020 at 6:30 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Nope, I shower in the morning and there is no water damage on the ceiling... I haven't touched it though. Pretty sure all the pipes are in the walls and not ran in the ceiling.
  11. Aug 6, 2020 at 6:31 AM
    Gritto
    Heh, you said Butts. :p
  12. Aug 6, 2020 at 6:36 AM
    OneGiraffe
    Tiffany
    NW MT
    I was thinking possible pooling from the humidity dripping from the ceiling. Hmm.... Do you have a solid vinyl floor in the bathroom or is it plank? Do you have any separation or holes anywhere that would show a leak? Also maybe try taking off the top of the toilet and seeing how high the water is? Maybe it's leaking occasionally and then pooling to the lowest spot on the floor.
  13. Aug 6, 2020 at 6:39 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Pretty sure its a solid vinyl cheap cut. I'll look for a line or seam in it, should be 1 piece, might be 2. Toilet bowl level was good last I checked, when I throw in one of them chlorine thingies a couple of weeks ago. This happens once every few months!!
  14. Aug 6, 2020 at 6:46 AM
    OneGiraffe
    Tiffany
    NW MT
    I guess my thought with the toilet was sometimes when the seal on the toilet is going bad it will think the water is low and sporadically run. If it's running occasionally then it may overrun spitting out a little excess water before thinking the flapper is back down and shutting off.
    Who knows, I'm just tossing out guesses. Whose our resident plumber? Isn't that reef?
  15. Aug 6, 2020 at 6:55 AM
    Gritto
    #SecretRevenge
  16. Aug 6, 2020 at 7:09 AM
    ReefSR54X4
    Jersey
    2016 BB AC SR5
    put some paper towls rolled up around the base of the shitter.. leave it over night. May be you wax ring
    also if it runs sometimes, high humidity from keeping the door closed, may cause the base to sweat, but normally it will puddle around the WC
    or.. look straight up from the puddle, your fart fan may be leaking when it rains..
    I could go on, and on, check these first
  17. Aug 6, 2020 at 7:11 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Will do! Appreciate it!
  18. Aug 6, 2020 at 7:11 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    :eek: so mebbe sumbuddy fatassed it.. :notsure:
  19. Aug 6, 2020 at 7:14 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I just sprayed it and rolled! Really didn't try to be careful.
  20. Aug 6, 2020 at 7:17 AM
    ReefSR54X4
    Jersey
    2016 BB AC SR5
    DONT PUT THOSE CHLORINE TABS INTO YOUR TANK!! It will warp every plastic piece inside, giving me 2-300$ of repairs
    Sammie, Gritto[OP], 1buzzbait and 2 others like this.
