Whats a good/cheap air compressor/pump that could pressurzie CostCo Waterport?
Discussion in '3rd Gen. Tacomas (2016+)' started by JacksTurdGen, Apr 14, 2019.
  1. Apr 14, 2019 at 7:14 PM
    JacksTurdGen
    JacksTurdGen [OP] 2018 double cab short bed
    third gen OR
    Only need for costco waterpump, want something that could plug into car cigarrette lighter or truck bed outlet.
    Only other use would be to fill an inflatable pool toy with a Boston Valve to a very low pressure. If it could do both that would be great, but not essential. I can get a pump for the pool toy for $13. Not sure what to do about costco. I just inlfate waterport now with a bike pump, takes a long ass time.
  2. Apr 14, 2019 at 8:01 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Skydvrr likes this.
  3. Apr 14, 2019 at 8:08 PM
    TechLizard
    TechLizard Active Member
    OC, Southern California
    '21 ACMT
    shakerhood likes this.
  4. Apr 14, 2019 at 8:31 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
  5. Apr 14, 2019 at 9:04 PM
    JacksTurdGen
    third gen OR
    Thanks for the slime tip - is there an adapter for boston valves for boat inflatables?
  6. Apr 15, 2019 at 7:03 AM
    snickers
    snickers My heaping pile of shit
    2018 TRD 4x4 DCSB OR Cement
    Thirty dollars is well on your way to getting an even more convenient cheap air compressor that will inflate your tires as well. And that manual pump is a moving part, so can't claim it won't break as well. But, beauty is in the eye of....
  7. Apr 15, 2019 at 7:07 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Good and cheap don't go in the same sentence well
  8. Apr 15, 2019 at 7:13 AM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Oahu
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    This little kobalt is great. I used it for years before I had OBA. Still use it from time to time. Set the desired pressure and hit the start button. Plugs into standard outlet or lighter plug.
  9. Apr 15, 2019 at 8:24 AM
    nvnv
    nvnv Well-Known Member
    Connor
    2016 Tacoma TRD OFF ROAD
    Buying from Costco it comes with the pump cap. At least it did last year.
    snickers likes this.
  10. Apr 15, 2019 at 5:31 PM
    mutely
    Use use any generic Boston valve adapter like this one
    https://www.amazon.com/SportsStuff-10-1010-Compressor-Adapter/dp/B0000AZ929
    If you want something with a little more “oomph”, that can also do tires, then this is about the best cheap option.
    https://www.amazon.com/Inflator-Por...words=MF-1050&qid=1555374377&s=gateway&sr=8-1
    The above has become very popular over the years due to its solid performance over others in this “class”, it can be had under a variety of brand names, but pep boys usually sells them for about $50.
    Google MF 1050 compressor and you’ll find a ton of information. But for what you originally asked the Slime is a very decent option. (Depending on the size of the Pool Toy)
    YF_Ryan likes this.
  11. Apr 15, 2019 at 6:09 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
  12. Apr 15, 2019 at 6:24 PM
    JacksTurdGen
    third gen OR
    This is good for car tire inflation as well? Safe for use?
  13. Apr 16, 2019 at 8:08 AM
    dustin19d
    Dustin
    Oahu
    Yes. Mines been going for over 5 years. Works great.
  14. Apr 16, 2019 at 8:28 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    @JacksTurdGen , I second this post about the MF 1050. I purchased it as the MV-50 for my old pickup. Used it to compress an air tank to run air horns. Removed it from that truck and installed in my Tacoma. Used it for the air horns again, and to air up ATV tires and my truck tires.
    Best place to buy is usually your local autoparts store. o'reilleys, napa, autozone, whatever.
  15. Apr 17, 2019 at 6:15 PM
    bluzharp
    bluzharp Well-Known Member
    Marion, TX
    19 OR DC LB Cement (the slowest color)
    Harbor freight has their version of the mf 1050. I've had mine for 12 years. I don't use it often but it has worked every time I've needed it.
    YF_Ryan likes this.
