What's a good shift module to eliminate trans hunting/shifting issues?
Discussion in 'Performance and Tuning' started by CVOTRDSPORT, Jan 27, 2025.
  1. Jan 28, 2025 at 8:08 AM
    CVOTRDSPORT
    CVOTRDSPORT [OP] Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    If I want to do that, I will go to a different platform, not a Tacoma
    skidooboy[QUOTED] likes this.
  2. Jan 28, 2025 at 8:30 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The transmission isn't the problem. The 3.5 engine needs a lot of rpm's to get power. The transmission needs to constantly shift to keep the engine rpm in the best rpm for power. Don't use 6th gear unless you're on the open road and at speeds over 65.
    Chew likes this.
  3. Jan 28, 2025 at 8:39 AM
    CVOTRDSPORT
    That doesnt work well either. The motor is way too underpowered to run a double overdrive. I drove from SF-LA ON highway 5 and almost every rise or elevated section of roadway, Id have to shift to 4th.
    kahanabob likes this.
  4. Jan 28, 2025 at 8:53 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    OTT Tune
    Mild Drive / Spicy ECT - current setting.
    I had my Sport 4 months and did not experience gear hunting before logging in TW.
    I'll use ECT in D when I want quicker acceleration.
    I use S4/S5 on random occasion just to engage...also engage 4H to make sure the system gets its monthly usage.
    Taco dv likes this.
  5. Jan 28, 2025 at 10:26 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    That was my round about way to suggest a different vehicle/platform. Really these are just glorified cars. I have had mine since 2019, and I have come to understand it's quirks, and limitations. I love the truck but, the trans/cruise control logic sucks the big donkey wiener. Throw a trailer on it of almost any weight, and it is worse. Ski
    Old metals likes this.
  6. Jan 28, 2025 at 10:57 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I'm only going to address one of your issues and that is "downhill compression hold back". I have noticed the same thing and think it probably exists on most all new vehicles, particularly those with an AT. This is how Toyota and I imagine most other manufactures make their gas milage goals with the FEDs. I notice how nice it is to get back into my 1986 MT vehicle.
    CB350G likes this.
  7. Jan 28, 2025 at 12:10 PM
    waffleiron
    waffleiron Well-Known Member
    Washington
    S mode
    S2 for sub 20s
    S3 for 20-40
    S4 for 45-60
    S5 for 65-75
    Keeps truck about between 2000-3000rpms which is a good place for the power band.
  8. Jan 28, 2025 at 2:11 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    That's what mine does without ECT on.
  9. Jan 28, 2025 at 2:41 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The variable valve timing changes at 3500rpms, above that is the power band.
    Lugging this engine below 3000rpms makes the shifting worse.
    BoomerGVNG likes this.
  10. Jan 29, 2025 at 6:14 AM
    waffleiron
    Washington
    Im sure it does change at 3500 being a vvt system and all. It also creates a wider powerband.
    I should probably edit my statement as I drive between 2500-3500. I dont go above 3000 often usually when passing, getting on a freeway.
    2500-3000 is my typical.
    Anyway my point, i disagree with you.
  11. Jan 29, 2025 at 7:30 AM
    CVOTRDSPORT
    I would tend to agree but when the speed limit is 20-25, the trans in 2nd is like 12-1500, so it’s futility at best
  12. Jan 29, 2025 at 7:33 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    how old is your tune?
  13. Jan 29, 2025 at 8:12 AM
    eurowner
    eurowner Duke Sky
    Scoty
  14. Jan 29, 2025 at 8:21 AM
    CVOTRDSPORT
    Version 1.3
  15. Jan 29, 2025 at 9:57 AM
    #35
    waffleiron
    Washington
  16. Jan 29, 2025 at 10:01 AM
    #36
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    I put it in S mode too. Only way to make the truck behave.
  17. Jan 29, 2025 at 11:00 AM
    #37
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Im thinking you havnt done somthing right I did an ov tune 2 years ago and it drastically helped. Did not eliminate it but it certainly helped alot.
  18. Jan 29, 2025 at 11:19 AM
    #38
    CVOTRDSPORT
    Ryan, I think youre absolutely right. In fact I never noticed any improvement or any changes for that matter. I wish there was someone I could take it to to do an upload near me (bay area, California)
  19. Jan 29, 2025 at 11:23 AM
    #39
    Big Cole
    Big Cole Well-Known Member
    I drive from LA to Sacramento on I5 twice monthly during ng duck season and have the same experience. I'm in in 6th gear going under 85 mph the truck downshifts on every slight incline. Throw in some wind and you're doomed.
  20. Feb 6, 2025 at 12:36 PM
    #40
    banjoGrampa
    banjoGrampa Well-Known Member
    David
    East Tennessee
    2019 TRD Sport 4x4 DCLB
    OME/ Bilstein 2" lift, Deaver aal Pro/Heritage grill TRD PRO wheels w/ Goodyear Ultraterrain 265/70/17 Westin HDX DROP NERF STEP BARS LEER 100R shell Custom bed platform High flow air filter/air accelerator Marine Corps graphics A-Premium mud guards Emblem black-out Rove R2-4K Dash cam
    The tune won't make it a race car, but you will notice it now feels like you'd expect a truck to fell. The HP and torque gains are not astronomical as they are designed to not over stress the engine.
