What's a good way to temporarily fix a scratch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AKTACO420, Oct 5, 2011.
  1. Oct 5, 2011 at 3:41 PM
    AKTACO420
    AKTACO420 [OP] Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    So I had an icedent were I scratched my hood pretty badly and was wondering what's the best way to paint it temporarily until I can afford to take it to the body shop. Thanks
  2. Oct 5, 2011 at 3:42 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm assuming it went down to the metal so you cant buff it out?
  3. Oct 5, 2011 at 3:44 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Yea it's all the way down to the metal
  4. Oct 5, 2011 at 3:48 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well I cant help you there. I'm sure more will chime in with a solution and what not. GL!
  5. Oct 5, 2011 at 3:50 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Thanks
  6. Oct 5, 2011 at 7:27 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    How big is the scratch? I would mask it off, sand it then put a coat of primer on the scratch. If you want it to look semi decent get some matching paint in a spray can and spray it.
  7. Oct 5, 2011 at 7:34 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    That's a good idea it's about a foot long with a few other scratches
  8. Oct 5, 2011 at 8:47 PM
    alexlies
    alexlies Well-Known Member
    Alex
    Battleground
    2002 4 door 4x4
    sticker!!
  9. Oct 5, 2011 at 9:27 PM
    sparkhill
    sparkhill Well-Known Member
    These chip and scratch products can work pretty well, in some circumstances. I like Dr Color Chip a little better.
    http://www.drcolorchip.com/
    http://www.langka.com/
    This place sells paint in spray cans that will be a pretty close match to your factory paint; metallic paint is a lot more difficult to match than non-metallic.
    http://www.paintscratch.com/
    You might be able to find a body shop to do a quick prep and spray for a reasonable amount of money and that will likely look better than any of the above options.
  10. Oct 5, 2011 at 9:58 PM
    808brian
    808brian Well-Known Member
    Brian
    Maui
    Black z
    Just use touch up for now till you repaint it
  11. Oct 5, 2011 at 10:02 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    hood is easy to repaint, since you can take it off. A rattle can base coat + clear coat will do a very good job on a hood. I suggest that you put some touch-up paint to alleviate rust in that area.
    If you just wanna do a touch up, you can sand down the scratches, touch up paint locally, sand down joints, touch-up clear coat locally then sand down joint. This can do a pretty decent job.
  12. Oct 6, 2011 at 3:45 PM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    Primer doesn't stop rusting, you need to keep oxygen away from the metal and primer is permeable. Only epoxy primers are non-permeable, I'm not sure how common or available it is.
    If the body shop is going to fix it eventually, seal the metal with some paint. If it won't be that long before you bring it in, stick your finger in some vaseline and run it along the scratch. It will keep the metal from rusting and will be a lot easier for them to get off, they can just wipe it off with some lacquer thinner or something similair.
  13. Oct 6, 2011 at 6:48 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Sweet thanks for the info guys
