whats better, a refurbished engine or a used???!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElkKiller4Life, Feb 20, 2013.
  1. Feb 20, 2013 at 12:22 PM
    ElkKiller4Life
    ElkKiller4Life [OP] Active Member
    Lewiston, Idaho
    05 TRD
  2. Feb 20, 2013 at 12:31 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    depends... who is doing the rebuild? How was the used engine treated? It can go either way.
  3. Feb 20, 2013 at 4:33 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Who did the refurbishing? Does it come with a warranty?
    With any USED anything - you're taking chances.
    What are the cost differences?
  4. Feb 20, 2013 at 4:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    $ for $, used.
  5. Feb 20, 2013 at 4:46 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Ummmmm...to all the seasoned people
    How does one refurb an engine with cast in place cylinder walls that are 5 sheets of paper thick?
    good luck
    new or used is the way to go.
    whats wrong with your engine OP?
  6. Feb 20, 2013 at 4:48 PM
    XXXX
    sKiP
    05 Prius
    do some reading
  7. Feb 20, 2013 at 4:53 PM
    d9lowe
    d9lowe Active Member
    '13 DC V6 4x4 TRD-OR
    You work for Clearwater?
  8. Feb 20, 2013 at 4:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A refurbishment doesn't always require boring the cylinder. You can still hone the cylinder.
    Boring doesn't equal honing.
  9. Feb 20, 2013 at 5:07 PM
    XXXX
    sKiP
    05 Prius
    Yea if you catch it early enough you can. Problem is how do you do that? By the time you notice its fubar chances are its fubar.
  10. Feb 20, 2013 at 5:13 PM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Most used may have at most 1yr warranty and don't pay labor. When remans are usually at 3yrs and pay labor. And it really depends on who does the the rebuild. I know at my work the chrysler engines have almost all new parts. It really sucks pulling an engine. Than having to do it again cuz the lkq (or what ever junk yard) engines end up being crap.
  11. Feb 20, 2013 at 5:47 PM
    XXXX
    sKiP
    05 Prius
  12. Feb 20, 2013 at 9:52 PM
    ElkKiller4Life
    Lewiston, Idaho
    05 TRD
    Its a autowrecking place. Toyota specialist. A REMAN... its about 300 more for it. And has a 18 month warranty. Im having a certified mechanic put it in but im not sure if its better to put a used 40,000 mile engine or a refurbished
  13. Feb 20, 2013 at 9:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    in that case I'd go used. Make sure they offer a warranty. Compression and leakdown test the donor if possible.
  14. Feb 20, 2013 at 10:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Agree.
    That being said, in my experience selling rebuilt engines at NAPA and Kragen, I would rather have a low mileage salvage engine than a parts store engine. NONE of the parts store engines held up. NONE of them! That includes the ATK rebuilts that I special ordered at customer's request.
    The best would be to get your's rebuilt locally by someone you trust. Given the design of the 4.0 V6, and the fact that you probably don't hang out with engine machinists (you would be asking them this question, not us), it's not likely that this is a realistic option for you.
    A couple of local mechanics have said good things about Densmore and Jasper engines, but I have no personal experience.
  15. Feb 21, 2013 at 1:17 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Coming from a guy who has rebuilt many many engines, I don't see how a used motor would ever be better than a rebuilt one. I would rather have one that has all new pistons, rings, bearings, etc., than one that already has 40,000 miles of wear.
    That being said, it all depends on who does the rebuild. If someone does a hack work job it probably won't last long.
  16. Feb 21, 2013 at 8:00 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    A good rebuilt engine will be like new, or in some cases when rebuilt for a specific purpose, better than new.
    Used is used, depending on how honest or well taken care of the original engine by the seller you are taking more of a risk but for usually less money. Some places offer a short warranty on used engines.
    If you rebuild the engine you just have to be sure you stay within the factory tolerances, and don't skimp on anything.
  17. Feb 21, 2013 at 1:02 PM
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    From what I'm reading, it really boils down to the $ you want to spend . Get a junk yard pull out,don't know how and why it's there, get a reman engine with some warranty, still taking the chance it's fails or get a certified engine from dealer have them put in and get a Toyota warranty, also why engine swing, I overhauled my Mazada engine with a import mechanic ,years ago it had over 160,000 miles on it, broke the timing belt, we overhauled it ,I STILL have this truck with the overhaul in it it now has 445,000 miles on it and my son still uses it everyday. if you decided to overhaul it make sure it's a import specialist, and a good shop and not a shade tree mechanic.
  18. Feb 21, 2013 at 3:05 PM
    ElkKiller4Life
    Lewiston, Idaho
    05 TRD
    Thanks everyone. I appreciate everyones input. This sights badd assss.
