Whats better for towing - SR or OR trim?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fgeorge097, Jul 4, 2018.
  1. Jul 4, 2018 at 10:57 PM
    fgeorge097
    fgeorge097 [OP] Well-Known Member
    Northeast
    2018 OR AT
    Pretty much as the title reads.
    Comments, please.
  2. Jul 4, 2018 at 11:43 PM
    adrian_tsn
    adrian_tsn Well-Known Member
    Adrian
    Oak Harbor, WA
    17 4x4 DCSB V6
    Bilstein 5100 w/ OME 887 Springs HS AAL w/ Overload TRD Pro Grille w/ Raptor Lights TRD Pro Shift Knob TRD Pro Skid Plate Morimoto HID and Fogs 285/75/16 Nitto Ridge Grapplers Method NV’s Westin Automotive Running Boards
    Depends on how much you plan on towing, but I think majority will say any Tacoma will do the job especially if you have the V6 with tow package.
  3. Jul 4, 2018 at 11:51 PM
    Avail211
    Avail211 Well-Known Member
    2016 BBP TRD OR
    Does the SR have the factory tow package + V6? If so, then either/or I bet.
  4. Jul 4, 2018 at 11:58 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    what are you towing?
    if youre going to back a boat down a wet ramp
    i would consider a v6 tacoma with 4x4
    shakerhood and medic2230 like this.
  5. Jul 5, 2018 at 1:25 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    The OR is going to have the 8.75” rear differential and the SR is going to have an 8” rear differential. In general a larger diff is going to live longer for towing duty.
    shakerhood likes this.
  6. Jul 5, 2018 at 2:49 AM
    frankied
    frankied Member
    fucking texas
    2016 tacoma trd sport 4x4
    I have the Sport 4x4 and towed a 3400lb uhaul horse trailer with a 1200lb horse from albuquerque, nm to rangely, co, through the rockies with no probs other than 8 mpg and that was before the transmission reprogram.
  7. Jul 5, 2018 at 3:06 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Generally what ever has a V6 engine and tow package.
  8. Jul 5, 2018 at 4:18 AM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Either will do the job.
    The SR will look better doing it..... :anonymous:
  9. Jul 5, 2018 at 6:58 AM
    gw204
    gw204 Well-Known Member
    If you are concerned with towing performance and willing to spend the coin for an OR....get a Tundra.
    Woodrow F Call likes this.
  10. Jul 5, 2018 at 8:03 AM
    SagWagon
    SagWagon Well-Known Member
    Geoff
    Portland, OR
    2022 TRD OR
    In my shopping around, I was surprised to find that because Totota gives rebates on Tundras, they could be had for cheaper than a Tacoma!
  11. Jul 5, 2018 at 8:28 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Can't find anywhere in the Toyota manual where it states the SR rear axle is different than the other models? they all have the same 9.4" of ground clearance? am I missing something?
  12. Jul 5, 2018 at 9:22 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Most likely this, but I will tell you that the OR has a larger rear differential due to the locking mechanism. If you think bigger = better, get the OR.
    What will you be towing?
  13. Jul 5, 2018 at 9:32 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    SR5 with the factory tow package does well. Everyone here forgets the SR5.
    Crasyrapy likes this.
  14. Jul 5, 2018 at 9:56 AM
    erics
    erics Well-Known Member
    Eric
    PA Slate Belt
    2018 Tacoma TRD Offroad 6-speed
    SR has smaller tires than the OR.
  15. Jul 5, 2018 at 9:58 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    All Manual Trans Versions along with Off Road and Pro have the larger 8.75" Rear.
    02Duck likes this.
  16. Jul 5, 2018 at 9:59 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    Models with either manual transmission, factory e locker, or both, have an 8.75 inch axle. All other 3rd gens have the 8 inch axle. All OR models have the factory locker, some SR(5) have manual transmissions.
  17. Jul 5, 2018 at 10:22 AM
    shakerhood
    Southern Ohio
    In the 3rd Gen no SR5 had a Manual and unfortunately the SR Manual was eliminated for 2018.
  18. Jul 5, 2018 at 11:03 AM
    specter208
    California
    Only smaller by a hair.
    kgilly likes this.
  19. Jul 5, 2018 at 11:08 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    I didn't think 1-1.5" was that big either for the tires..
  20. Jul 5, 2018 at 11:15 AM
    specter208
    California
    SR and SR5 use 245/75/16 = 30.5 in tall
    TRD OR use 265/70/16 = 30.6 in tall
    Tire width difference is 0.8 in.
