What's better to jack a tacoma double cab? High lift jack or jack stands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Nov 13, 2011.
  1. Nov 13, 2011 at 9:27 AM
    jw1983
    jw1983 [OP] Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    At a local auto store they have a 60 inch high lift on sale and jack stands. I am not sure of the pluses and minuses of these products? I'm just use to using the crap jacks that I get with cars. Any help would be great, thanks!
  2. Nov 13, 2011 at 9:29 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    High lift is for trail jacking. Hydraulic jack w/ jack stands is for doing work on your truck, ie rotating tires, installing lift kit
  3. Nov 13, 2011 at 9:43 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The High Lift would be best used with heavy aftermarket bumpers and welded on sliders to handle the weight.
  4. Nov 13, 2011 at 9:47 AM
    jw1983
    Alberta
    I'd use it more for on the side of the road repairs and what not. That's pretty much it. I don't have a garage so I won't be doing anything else under the truck.
  5. Nov 13, 2011 at 9:52 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Unless you have a place to lift from (aftermarket plate bumpers or sliders) a high lift will do you no good.
    G.T. likes this.
  6. Nov 13, 2011 at 9:55 AM
    jw1983
    Alberta
    That's what I was wondering. Because I know that the jack stands go under the points under the truck(says the manual) to lift it to do minor things like tire repairs, changes etc. I'm starting to think that a high lift wouldn't be a good idea since that I only have stock bumpers etc.
  7. Nov 13, 2011 at 9:58 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Jack stands don't lift as stated ^ they just hold once you use a jack to lift.
  8. Nov 13, 2011 at 10:00 AM
    jw1983
    Alberta
    Omg! I am so confused. Cars are so much easier lol. So is it one or the other or neither. lol
  9. Nov 13, 2011 at 10:01 AM
    jw1983
    Alberta
    So get the high lift jack? Or another kind of jack?
  10. Nov 13, 2011 at 10:03 AM
    jw1983
    Alberta
    recommendations?
  11. Nov 13, 2011 at 10:03 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    do you have sliders or an aftermarket bumper? if you dont you really cant use the high lift that easily to change a tire, you would need a high-lift receiver for your hitch to lift the back , and also install some kind of jack lift point up front
  12. Nov 13, 2011 at 10:04 AM
    OffroadToy
    For on the side of the road repairs concider a bottle jack that has a higher lift rate and a few blocks of wood. Also, a chock and a couple jack stands.
  13. Nov 13, 2011 at 10:04 AM
    pudge151
    Sean
    Connecticut
    go to harbor frieght and get a jack and stand combo, if you need a jack for changing a tire on the roadside then use your OEM jack, it works
  14. Nov 13, 2011 at 10:07 AM
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    The jack stands do not lift the truck! You still need a jack. Once you use the jack to lift the truck, you then place the jack stands under it so that if it were to slip off from the jack, it will not crush you.
  15. Nov 13, 2011 at 10:07 AM
    jw1983
    Alberta
    Nope, everything is stock. No sliders or aftermarket bumper.
  16. Nov 13, 2011 at 10:08 AM
    jw1983
    Alberta
    Now the grasshopper understands. I'm such a noob lol.
  17. Nov 13, 2011 at 10:09 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    For side of the road repairs, I would get a bottle jack that lifts higher than the stock jack. A typical floor jack will take up way too much room.
    Jack stands do not lift the vehicle. They are used in conjunction with a floor jack to support the weight of the vehicle in case the jack fails. BTW always use jack stands! Can't stress that enough. My buddy almost lost his leg because we were 16 years old and stupid, working on a car without jack stands. The jack broke, the car fell and almost took off his leg, fortunately he pulled his leg out from underneath the car just in the nick of time.
  18. Nov 13, 2011 at 10:10 AM
    pudge151
    Sean
    Connecticut
    bottle --- pump---- stands ---
  19. Nov 13, 2011 at 10:17 AM
    jw1983
    Alberta
    Thanks for the links. I think that a pump jack and jack stands would be a great idea. Thanks for stopping for making me getting a high lift jack and only jack stands.
  20. Nov 13, 2011 at 10:51 AM
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    If your truck is stock, why not use the stock jack that came with it :confused:
