What's better to jack a tacoma double cab? High lift jack or jack stands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Nov 13, 2011.
  1. May 15, 2012 at 1:32 PM
    #41
    DavidS
    DavidS Well-Known Member
    Dave
    Pacific Northwest
    2012 Tacoma TRD Sport
    Another safety concern... Always wear nitrile or laytex gloves when removing zombie bits from your vehicle. Do not allow blood or other body fluids to come in contact with your skin. One can't stress enough the contagious nature of this material. I keep a few pairs in my tool kit "just in case".
  2. Apr 10, 2013 at 3:43 PM
    #42
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    This happend to me many years ago. I was working on my 74 chevelle had it on jack stands front wheels off on a nice hot California day. The surface I was on was blacktop or asphault as some call it I was half under the car when I noticed it started to move. Long story short I got out of there pronto as soon as I was out standing there looking at it saying WTF blam the front of car was laying on the ground on its front brakes.
    Here is what happend when blacktop gets hot it also gets soft legs of jack stands sank in and the rest is history.
    Minor damage to my Chevelle a couple of bent backing plates for the brakes.
  3. Apr 10, 2013 at 4:25 PM
    #43
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    Fwiw hi lift makes a kit that lifts from the wheel instead of the bumper. Search Amazon, it's like $30 or so
  4. Oct 15, 2015 at 8:24 AM
    #44
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Did a lot of searching to make sure i asked this in the correct thread.
    Looking at the owners manual for my 2015 the rear jacking points are on the rear axle below at the point the springs are located.
    But its hard to tell what the front ones are???. From the looks of it they are on the frame?? Note, I will be using a trolley jack if that makes a difference.
    Seeing that the rear points are on the axle will make changing the rear tires a lot easier since very little lift will be required to get the tire off the ground compared to all my other vehicles where jack points are on the body.
    The reason I am asking is that I have always done my own summer/winter tire swaps since I don't want any gorilla with a impact wrench installing or removing my wheels. Even though i have an air impact I still use a breaker bar to loosen the nuts since I have seen the damage to the chrome plating on the lug nuts that impacts can do.
  5. Oct 15, 2015 at 8:35 AM
    #45
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Right after I got out of high school, I joined our local volunteer fire dept. The very first run I made was where a guy was working on a small farm tractor and had it jacked up with a stack of wooden blocks and a small bottle jack. The blocks shifted, causing the tractor to fall. A rear brake drum came down on his head and killed him instantly. I have the image forever burned into my memory. To this day I'm OCD about jacks, jack stands, and making certain things are safe before I crawl under a vehicle. I like working on my Tacoma, but not NEARLY so much that I'm willing to die over it. Be safe. Most of us have never actually met, but we are ALL friends and no one wants to see a friend get hurt.
    Festus and DrFunker like this.
  6. Oct 15, 2015 at 9:31 AM
    #46
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I just use a 2.5 ton jack with 4 tons jack stands.
    I also use a 4"x4"x4" block of wood on the jack to get it to the appropriate high.
  7. Oct 15, 2015 at 9:46 AM
    #47
    mdne04
    mdne04 Well-Known Member
    Eduardo
    Weslaco, Texas
    DCSB TRD Off-Road 4x4
    OME 3" kit (885's), LR-UCA's, Dakars, Ext. rear brake lines
    I went free route on this. Friend is building a house, I took some wood from the trash pile to put under my stock jack.
  8. Oct 15, 2015 at 10:33 AM
    #48
    babylon5
    David
    100% in agreement. Neighbour was going to change a sway bar end link on his mazda after I checked it out and saw it was broken. Saw him going out to change it using the factory sicsor jack. Before he even started i ran out with my trolley jack and jack stands since i wanted him to be around for his kids.
    Like the 4X4 tacoma since its high enough that I can even change the oil without putting it up on ramps.
  9. Oct 16, 2015 at 6:20 AM
    #49
    babylon5
    David
    So back to original question :)
    What is the recommended location to place your jack to do the front?
