Whats brighter than HID's
Discussion in 'Lighting' started by elblako91, Mar 29, 2011.
  1. Mar 29, 2011 at 8:15 PM
    elblako91
    elblako91 [OP] Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Is their anything brighter besides possibly LED?
  2. Mar 29, 2011 at 8:26 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    besides the sun, nothing as far as vehicle lighting.
  3. Mar 29, 2011 at 8:34 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    amo-led?
    oh thats phones
  4. Mar 29, 2011 at 8:36 PM
    Sixfeathers
    Sixfeathers Well-Known Member
    Kreg
    Maryland
    2011 Access Cab
    Led lights: Replaced Bulbs in front,Fog Light modification, Westin Nerf Bars, TS mod,
    my neighbors bum
  5. Mar 30, 2011 at 5:48 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    GLE's
    God's Lightning element.
  6. Mar 30, 2011 at 6:10 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    There's brighter lights out there, just not much that would be at home on a vehicle. First thing that comes to mine are the flood lights on boats or the ones used to light up building exteriors. I believe their sodium lights? I don't know if you can mount them to a truck though and doubt the electrical system would handle them (not to mention they're huge). Just add more lights and aim them properly. Just out of curiousity, what are you looking to do?
  7. Mar 30, 2011 at 7:05 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    aircraft landing lights.
  8. Mar 30, 2011 at 4:11 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    The best you can do is boosting HID ballast to put out 50-55W instead of 35. Otherwise, your other choice is using multiple HID lights.
  9. Mar 30, 2011 at 4:11 PM
    shredtacoma
    shredtacoma Well-Known Member
    Jace
    SOCAL
    07 Prerunner Debadged with snugtop
    Camburg lift, ProComp rims, Nitto Terragrappler tires, snugtop, Flowmaster exhaust and Airraid intake
    hid retrofit
  10. Mar 30, 2011 at 4:41 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    LEDs are the only way to go. HID head lights put out around 3200 Lumens each. So about 6400 lumens for two. Now lets compare to some LED bars.
    Rigid Industries 20" Bar (Double stack)
    7200 Lumens
    Rigid Industries 30" bar (Double stack)
    10800 Lumens
    Rigid Industires 40" bar (Double stack)
    14400 Lumens
    Rigid Industries 50" Bar (Double stack)
    18000 Lumens
    baja Industries Stealth XPG 40 LED bar (Single Stack)
    14000 Lumens
    The Vision X 3W Bars are comparable to the Rigid Bars (Xmitter Series)
    But their 10W per LED bars are crazy (Evo Prime)
    Vision X EVO Prime Single Stack 20"
    10,320 Lumens
    Vision X EVO Prime Single Stack 30"
    15,480 Lumens
    Vision X Evo Prime Single Stack 42"
    22,360 Lumens :eek::eek::eek:
    I have seen the 40" Rigid bar in person and it is CRAZY how bright it is. Can imagine how bright the evo prime 40" is.
  11. Mar 30, 2011 at 4:43 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    electric light orchestra
  12. Mar 30, 2011 at 4:46 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  13. May 8, 2011 at 9:47 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Lumens doesn't tell you how bright it will illuminate something, only how much actual light it is outputting. Those lightbars are no good for headlights since they disperse the light over a big area. Great for wide area lighting on the sides of your truck etc.
    Some leds are approaching levels near what is needed for a headlight and there have been several prototypes, but its just tough to get a big enough semiconductor die and get all the heat it generates away from the die itself.
    To answer your question, there is nothing brighter for your vehicle than HID's. The upper limit of HID's avail for vehicles seem to be ~55W. But HIDs exist in FAR brighter configurations. Pot growers use >1000W HIDs, and stadium lights etc are also very bright.
    All you can really do go higher wattage! The problem with this is in vehicles the arc tube gets bigger and bigger so you need a bigger projector/reflector to focus it, and it quickly becomes impractical. You could try run a 500W HID with fat cables from the battery and relays etc, but tough to built a custom light/reflector and make it all work without melting :D
