What's Draining My Battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Airborne22, Mar 23, 2023.
  1. Mar 23, 2023 at 11:25 AM
    Airborne22
    Airborne22 [OP] It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    Hey all, I am having an issue with my battery draining and I can't figure out what's doing it. I thought it was my dash-cam, but when I left for my trip a week ago I unplugged it and my battery still died. Any ideas on what I can use to see what my battery is putting out while the truck is off?
  2. Mar 23, 2023 at 11:27 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Google is your friend.
  3. Mar 23, 2023 at 11:28 AM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    Ok. If thats your answer, please save it. I posted here to see if anyone here has had similar issues or knows of a solution. If not, keep it to yourself.
  4. Mar 23, 2023 at 11:33 AM
    freddyfoxx
    freddyfoxx Active Member
    Bay Area, CA
    2005, 4Cyl, 5MT, 5lug, fishing mobile
    I've had this issue in a Toyota Avalon some years back. After 4-5 days of not driving, the battery would be dead. When I took to dealer they couldn't debug or find any issues. Turned out to be door sensor. Lexus' had similar issue. Not sure if this for your Tacoma but something to look into. Good luck.
    Airborne22[OP] likes this.
  5. Mar 23, 2023 at 11:36 AM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    Thank you. I do have several things running on the fuse box, but they should all be when the truck is on. Is there a type of meter I can use to see if there is a draw on the battery when the truck is off? I have a multimeter, but am unsure how to use it for this application.
  6. Mar 23, 2023 at 11:36 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    How long is it taking to drain the battery? from full charge or partial?
    Can you confirm whether the alternator is charging it or not?
    Any other aftermarket electronics that could be draining it?
  7. Mar 23, 2023 at 11:37 AM
    Bishop84
    Bishop84 Well-Known Member
    Watch a video on YouTube how to measure parasitic draw on a car battery.
    Also have the battery professionally tested. New doesn’t mean good.
    RustyGreen, Skydvrr, eurowner and 6 others like this.
  8. Mar 23, 2023 at 11:37 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Google will teach you how to use the multimeter for that.
    :rofl:
  9. Mar 23, 2023 at 11:39 AM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    I parked at the airport on Tuesday of last week and when I got back yesterday, the truck wouldn't start. There is no indication that the alternator is not working and the ONLY other thing that is tied to the electrical system and not constant on is my 12-volt solutions remote start.
  10. Mar 23, 2023 at 11:40 AM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    :censored:
  11. Mar 23, 2023 at 11:52 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Unplug EVERYTHING thats aftermarket. And by that I mean unplug it by disconnecting the positive lead from whatever source you tapped it from, don't just unplug it at the device. (Cheap relays and volt converters can and sometimes do leak.) You're going to have to do that anyway when investigating with a m.m., so you might as well start by pulling all of it. And if your battery still shows significant voltage drop after a day of having all aftermarket stuff unplugged, you would then need to start investigating your battery and your stock circuits.
    LoMa, Stevie17, RustyGreen and 6 others like this.
  12. Mar 23, 2023 at 11:53 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Could be anything. If CAN networks don't go to sleep, they can drain the battery.
    Start with any electrical addons. Lock the truck, unplug all addons and put a voltmeter on the battery to check the load. There are some tools that can log the data over a long period of time.
    Check Pine Hollow diagnostics YT channel for troubleshooting strategies.
  13. Mar 23, 2023 at 11:55 AM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    Thanks all! I appreciate your help. Anyone running the KTJO4X4 HUD have issues with battery drain?
  14. Mar 23, 2023 at 11:55 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Just brainstorming here, but I think you could use your multimeter at the fuse box with the car off and battery connected to see if a particular fused circuit is drawing power. Pull that fuse for a short term fix until you find the culprit on that fuse circuit.
    kahanabob and Airborne22[OP] like this.
  15. Mar 23, 2023 at 11:59 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Yes....use a simple multi-meter. Set it to the highest amp setting. Disconnect the neg battery terminal and put the meter leads between the battery neg and the vehicle neg lead. Look at the reading. Normal reading would be only a few thousand mill-amps.
    If it was me, I would take an initial reading...then disconnect any and all after-market devices. Then take another reading and see if its lower. Probably will be.
    Also, be aware that when you initially connect your meter each time, the amp draw will be higher since the vehicle has been "awaken"...it can take up to 30 seconds for the draw to settle down as the vehicle goes back asleep. Be sure doors are closed and lights not on. Even the hood being up puts a display on the dash.
    Airborne22[OP] and Captqc like this.
  16. Mar 23, 2023 at 12:01 PM
    randyb87
    randyb87 Well-Known Member
    RANDY
    Denver, Colorado
    2017 TRD Off-Road Shortbed - Quicksand
    ADD Honey Badger Front Bumper TRD Pro Grille Raptor Lights 6 Baja Designs Squadron Pods (Bumper) 2 Baja Designs 10" Amber S8 (Bumper) Switch Pro 9100 Dobinsons Lift Kit and Leaf Pack - 2.5" lift Smittybuilt 9500 Synthetic Winch Factor 55 Flatlink Ultra Hook Meso JDM Stage 1 Taillights Meso JDM Ultimate Turn Signals Meso JDM Stage 2 TRD Pro Shifter ARE z series topper Hood Decal Bed Side Decals Meso JDM 7 switch panel for console with Cig lighter port Clazzio Nappa Leather Seats with heaters 5 TRD Pro SEMA T4R Falken Wildpeaks 275/70/r17 UpTopRack XL and EX - With meso light pods (6 baja rock lights; 2 baja s2 flush lights) 40" Baja Design S8 Dual Mode Light bar on UpTopRack ARB Single compressor Expedition Essentials Air on Board Mount in Bed Cubby RSG Rock Sliders with top plate with kickout CBI full skid plate - powder coated CBI High Clearance Rear Bumper with 2 Baja Design S2 flush mount reverse lights 8 Baja Design Rock Lights under vehicle DSIM Dome Light Mode Dashboard Multi Mount by Taco Garage Inverter Adapter with in Cab Power Outlet ARB Fridge with hardwire ports in back of center console and in truck bed cubby Rhino Rack Batwing 270degree awning
  17. Mar 23, 2023 at 12:03 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    If it was mine..i would put an amp clamp on it..could be a bad cell in the battery,or a draw.
  18. Mar 23, 2023 at 12:57 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    how old is the battery, do you have the smart fob/push button ignition, when was the last time you FULLY CHARGED THE BATTERY on a battery tender/charger? our newer vehicles have so many communications RF transmission, & seeking, and monitors on them, they will discharge a marginal battery very quickly. I truly charge the batteries in our vehicles once every 4-8 weeks, even if they are a daily driver. the alternators are not designed to restore batteries to full charge on short trips. Ski
  19. Mar 23, 2023 at 1:01 PM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    The battery is a couple of years old.
  20. Mar 23, 2023 at 1:11 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    o_O
    This the 4th thread this week with people having electrical issues with aftermarket electronics in their truck…..hmmmm, seems to be a trend.
