What's everyone using for insulation???
Discussion in 'Tonneau Covers, Caps and Shells' started by Mikenewgun87, Aug 19, 2019.
  1. Aug 19, 2019 at 5:45 PM
    Mikenewgun87
    Mikenewgun87 [OP] Active Member
    Sparta, Wi
    19 Cement DCLB OR
    I'm looking into getting an ARE CX hardshell for sleeping in. For work, in the Midwest, sleeping in it is going to require insulation and heat.
    What about heat? Invertors for the heat???
    So many questions, so little time.
    Thanks in advance.
  2. Aug 22, 2019 at 7:43 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Reflectix foil insulation works well over the windows. Foam padding on the floor. Heating from an inverter is a no-go. No battery has enough capacity to power a heating element of any significance. Small propane heaters like the Mr Heater Buddy series may work to heat the space before bed and in the morning. However, understand the dangers of CO poisoning. Propane heaters have killed many campers.
  3. Aug 23, 2019 at 8:52 PM
    gnardoggie
    gnardoggie Well-Known Member
    mr buddy creates a shitload of condensation - your best bet is a good sleeping bag and a hot chick.
    stbear, Nevin and truchador like this.
  4. Aug 23, 2019 at 9:07 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    https://www.amazon.com/Suburban-243...coding=UTF8&psc=1&refRID=9QAPR03WDP58RTZ25WDS
    Maybe something like this? Might require cutting your new shell tho, it has supply and exhaust vents
