What's everyone's take on the 'easy' oil drain plug solutions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, May 19, 2020.
  1. May 19, 2020 at 10:14 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, that shouldn't be a thing unless you're the Hulk, or you're not using the correct size wrench.
    I'm sure there's a torque setting, but it's hardly necessary to set a torque wrench on it. It only needs to be just tight enough not to leak. It's not rocket science.
    I'm generally not a fan of replacing something with zero moving parts with something with moving parts.
    golfindia likes this.
  2. May 19, 2020 at 10:17 AM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    In all honesty it’s pretty hard to fuck yourself when the torque specs are generally around 30 lb ft.
  3. May 19, 2020 at 10:19 AM
    jbrandt
    Justin
    and both are unnecessary for changing the oil, lol
    SilverBullet19 and jsi like this.
  4. May 19, 2020 at 10:19 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    I put Fumoto valves on every vehicle I get the first time I change the oil. Never had one leak or get knocked off or anything of the sort. It's nice putting a hose on the nipple and draining straight into a bottle.
  5. May 19, 2020 at 10:20 AM
    jsi
    jsi Well-Known Member
    native earthling
    Unless you're rebuilding engines this torque wrench is more than adequate for most every home mechanic task. (and it's less money than that silly valve.) After a while of using it you'll develop muscle memory of just how tight things need to be. That statement will piss off the torque Nazis though. I've spent enough time down their rat hole to know that in the real world the torque given from even the most expensive wrench is just an approximation. If you need precise torque then you have to use something like this:
    Torque is measured using clean, dry, undamaged threads. There is no reasonable way to get that without removing the oil pan. :rofl: I'm trying to save you from the Nazis, sometimes tight enough is good enough. The trick is knowing when OCD is required and when it isn't.
  6. May 19, 2020 at 10:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    According to this chart and torque reduction, if you're torquing to 30 ft lbs while wet it's really closer to 50 ft lbs. At least that's how I understand it. That's a pretty significant difference. I just bring it up because I've seen people make matters worse by using a torque wrench vs going by feel when it comes to certain things like oil drain plug or spark plugs.
  7. May 19, 2020 at 10:21 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    The old way is pretty easy already.
  8. May 19, 2020 at 10:27 AM
    StillNoPickles
    2020 RAV4 Hybrid LE
    Maybe Toyota assumed wet specs or dry specs in the manual. I feel like they have to keep it easy enough for the most basic tech to understand (if they even use torque wrenches like they should).
    who knows lol. I’ve been doing it for years and have yet to have an issue. Knock on wood. Just a habit I’ve gotten into I guess.
  9. May 19, 2020 at 10:40 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Oil dain plug is about the only thing I never torque on my vehicles.
  10. May 19, 2020 at 10:45 AM
    jsi
    native earthling
    The only reason a tech should use a torque wrench is if they are a complete idiot. Wait . . . given what I've seen on those rare occasions I do go to the quicky lube places, techs should use a torque wrench. :rofl: I'll confess my last lube job was done at one of those places. The MoFo that put the drain plug and oil filter on most definitely did not use a torque wrench. They were on there TIGHT, way too tight.
    While I'm confessing I've been known to reuse the copper gasket :eek: if I don't have a replacement handy. It's an oil change, not rocket science.
  11. May 19, 2020 at 10:53 AM
    jbrandt
    Justin
    HF is cool, and I buy a lot there, but I have a hard time trusting anything with more than 1 moving part or has electricity running through it, lol. I know some of their products are supposed to be getting better, but I still don't trust them to really be making "quality" products.
  12. May 19, 2020 at 11:18 AM
    Balockay
    Blake
    Cleburne, TX
    Their ICON torque wrenches have been absolutely wonderful for me. That said, they're generally not in the price range most people are talking about when they say "HF tools".
    Black97v6MT and TRD493 like this.
  13. May 19, 2020 at 11:20 AM
    1997tacomav6
    Denver
    From Google reviews these valves thread into the oil pan sticking above the bottom of the pan inside so when used they don't allow ALL the oil to drain.
    That last 1/2" or 1/4" is not drained and thats where the oil crap falls that you want out of there.
    Black97v6MT and YE2KA like this.
  14. May 19, 2020 at 11:30 AM
    jbrandt
    Justin
    True, I was just looking at them and they're mostly in the $150 range.
    I know that HF has been "trying" to increase the quality of some of their stuff lately, or at least market themselves as such. A lot of people like their new welders.
    I honestly think they're going in the wrong direction if they intend to redefine their business model as a source for mid-level tools and equipment. There is a lot more competition there. I go to HF for a tool that I'll likely only need once or twice, if it last longer than that, that's icing on the cake. But if I need a good tool I'll use a lot, there are other places I'd go.
  15. May 19, 2020 at 11:31 AM
    #35
    donlogan
    donlogan [OP] Well-Known Member
    A guy on YT does a video and checks for this. He measured how much oil was drained out and concluded it was pretty much the same as he put in. This was my concern as well. Especially since the Corolla drain plug sits at angle and not at the bottom.
    edit- this for the Fumoto valve
  16. May 19, 2020 at 11:39 AM
    #36
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I think the best reason for the drain valves is when using an aftermarket skid plate (can't believe this hasn't been mentioned yet). It's way easier and worth the slightly slower drain time to not have to drop the skid to change the oil. I ran the stock plug for 120k miles and then put an ez drain on when installing my skids. Low hanging valve isn't really a concern with a real skid protecting it.
    All this preventing wear and tear on the threads stuff is really over thinking it. If you don't gorilla it on and use some common sense the plug and threads will easily last the life of the engine just fine.
    TRD493 and SilverBullet19 like this.
  17. May 19, 2020 at 11:39 AM
    #37
    1997tacomav6
    Denver
    Yup, but will still hold back the most dirty part of the oil
  18. May 19, 2020 at 11:46 AM
    #38
    Balockay
    Blake
    Cleburne, TX
    Dirty oil is good for your engine. Its helps build its immune system.
  19. May 19, 2020 at 12:31 PM
    #39
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I put a fumoto on all my cars, too. It's easy to use, clean, no leaks, and no dropping the plug in the drain pan.
  20. May 19, 2020 at 1:05 PM
    #40
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    I could see myself installing one for that reason. Otherwise, it's just so easy as it is I don't see a need.
