What's going on with my coolant?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacospecial, Aug 1, 2022.
  1. Aug 2, 2022 at 7:08 AM
    #61
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    This is exactly why he should go to the dealer. Its a brand new 40k+ truck. Let them deal with it.
    69 Jim likes this.
  2. Aug 2, 2022 at 7:31 AM
    #62
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The little crustyness on that hose is somewhat normal, mine will form that after a hard drive up the mountain in 90°+ weather and the AC running. There's no clamp on that hose. Both my 2nd and 3rd gens do this.
    Now being low on coolant, this is not normal. You can add some and keep and eye on it, or take it strait to the dealer where they'll likely fill it and send you on your way. However, it'll be documented if you take it to the dealer.
    Skydvrr likes this.
  3. Aug 2, 2022 at 8:01 AM
    #63
    tacospecial
    tacospecial [OP] Member
    Austin TX
    Update: I ended up taking it to the dealer after work yesterday. They said this happens sometimes because the factory fills up the coolant but doesn't wait for the air to come out by running the engine. This causes it to be low once the air bubbles out. That's also potentially why there's crusted coolant on the outside (or that could be unrelated). They filled it back up and I'm just going to check on it periodically.
    0xDEADBEEF likes this.
  4. Aug 2, 2022 at 8:09 AM
    #64
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Sound advice. :thumbsup:
  5. Aug 3, 2022 at 1:41 AM
    #65
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I would still add a hose clamp to it. I added one of the pinch kide to mine when I bought it new 4 years ago.
  6. Aug 3, 2022 at 2:12 AM
    #66
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    I'd be asking why that dealer didn't check it as part of the PDI.....
  7. Aug 3, 2022 at 3:15 AM
    #67
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    Is the underfilling of fluids, for example: coolant, oil, or ATF a known or common issue to be cautious of when picking up a new truck? :eek:
    With power steering, brake, windshield washer fluid, coolant (overflow tank anywhere / somewhere between Full and Low) or oil levels, I'm competent to check these myself. When the truck is presented before paperwork signing, I'm not sure how to verify the transmission fluid level (unless there is a dipstick up front in the engine compartment for that). Is the only method there to get under the truck, find the fill plug, sing a tune and hop on one leg?
  8. Aug 3, 2022 at 12:40 PM
    #68
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    That works too.
    69 Jim likes this.
