What's needed for towing?
Discussion in 'Towing' started by kalsonc, Jul 1, 2018.
  1. Jul 1, 2018 at 6:41 PM
    kalsonc
    kalsonc [OP] Active Member
    New to the forum
    Currently in the market a truck
    Looking at the Tacoma or F-150
    I tow an enclosed trailer (20x8.5) with a race car (1250lbs)
    The Tacoma fits all the boxes because it's shorter (I live in a townhouse complex and parking is limited)
    The f150 is too long for the parking spot that my neighbours probably wouldn't be too happy about lol
    Anyways back on topic,
    Based on my readings on the forums it seems I'll need couple things to make my Tacoma better for towing
    1) stiffer springs in the rear
    2) reflash
    Anything else comes to mind?
    The total weight of towing is only around.... 4750lbs with gear
    Any insight, tips are greatly appreciated in helping me
    Thank you
  2. Jul 1, 2018 at 7:04 PM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    Make sure you have trailer brakes. You’ll need a control if they are electric. You might need a sway control and or a weight distribution hitch.
  3. Jul 1, 2018 at 7:07 PM
    kalsonc
    Ya trailer brake controller is a must
    Sway control gotta look into
    But the rest of the stuff am I good in thinking is what I need to be more future proof?
  4. Jul 1, 2018 at 7:12 PM
    Kelly6773
    Kelly6773 Well-Known Member
    Bob
    SC
    18 TRD sport DCLB
    How far are you towing the trailer? Hills? If your towing on hills or mountain terrain. I’d think twice on the Toyota. Also if your towing every weekend.
    Mtn Mike likes this.
  5. Jul 1, 2018 at 7:15 PM
    kalsonc
    Realistically probably only 4-8 times a year
    It's from Vancouver bc to Shelton WA, so roughly 360km each way
    Not a whole lot of hills, even if there is it's not crazy steep
  6. Jul 1, 2018 at 7:17 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    Looks good to me. When you say reflash are you referring to the OVTune? I definitely think that would help. My camper is about 1000 lbs. less than your setup, if I had any more tongue weight I'd need stiffer springs or a weight distribution hitch. Passing big rigs can kind of upset my trailer sometimes so I think I'm border line on the sway control. Keep in mind that's a heavy load for a Tacoma. Make sure you get the towing package.
    kalsonc[OP] likes this.
  7. Jul 1, 2018 at 7:28 PM
    Kelly6773
    Bob
    SC
    18 TRD sport DCLB
    Well then get ordering! And enjoy
  8. Jul 1, 2018 at 7:38 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    If you don't mind driving stick, a Tacoma MT is the way to go! Tows about 2000lbs as good as my dad's 2012 EcoBoost.
  9. Jul 1, 2018 at 8:04 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Sumo springs or an air suspension would be a benefit. Also an equalizer hitch would help a lot.
  10. Jul 1, 2018 at 8:06 PM
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    Thats a lot of trailer, but I guess it's comparable to most campers dudes here tow. I'll echo everyone above, brake controller, wd hitch and sway control would be a must....you'd be more comfortable in a full size I bet though .
  11. Jul 2, 2018 at 8:17 PM
    kalsonc
    Test drove one today
    It was comfy and good
    So far on my list of must have:
    Husky Center Line Weight Distribution w/ Sway Control - Trunnion
    Tekonsha Prodigy P3 Trailer Brake Controller
    And stiffer rear springs
    Now... What's the recommendation for rear suspension upgrade ?
    I've looked at my trailer again (cargomate 20x8) it's only 2900lb with my car weighting 1250lb
    Total of 4150lb
    Do I need ovtune ? Or not really?
  12. Jul 2, 2018 at 8:20 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Reflash was only done on early 16's trannys.
    Air springs work fantastic as they are adjustable to any load.
    Brake controller and E brakes on trailer are a must.
    Flat or hilly terrain ?
  13. Jul 2, 2018 at 8:25 PM
    kalsonc
    Mainly flat
  14. Jul 2, 2018 at 8:29 PM
    2016Tacoman
    J
    You'll be good at 5k.
    I have air lift suspension and ebrake. Tows fantastic at 5k.
    kalsonc[QUOTED][OP] likes this.
  15. Jul 2, 2018 at 8:30 PM
    kalsonc
    which air lift suspension do you have?
    i'd prefer stock height - since i wont be off-roading
    how about sumosprings? which should i look at
  16. Jul 2, 2018 at 8:35 PM
    2016Tacoman
    J
    https://www.4wheelparts.com/Towing/...2362.aspx?t_c=67&t_s=2&t_pt=9332&t_pn=FIR2362
    Don't remember off hand if that is the exact number kit required, but you get the idea. I can look tomorrow.
    https://www.4wheelparts.com/Suspens...00.aspx?t_c=1&t_s=546&t_pt=4110&t_pn=AIR72000
    I like the airlift because I can adjust it perfectly to any load. More $$$ but worth it IMO.
  17. Jul 2, 2018 at 9:37 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I would get the F150.
    Yes your numbers say it’s possible. But it’s a 20’ car hauler and that is a whole ton of aerodynamic drag. My 14’+2.5’ v-nose pulled by my Tacoma spends its time in 4th gear. Forget about 5th it just won’t hold it unless going down steep hills. That is with a motorcycle and not a car inside. The drag makes higher gears impossible.
    Now lots tow right up to the maximum and say it’s fine. Myself I wouldn’t want to tow your rig with a Tacoma. If I had to pull mine week in and out I would go back to a full sized. Yours I wouldn’t want to pull across town.
  18. Jul 2, 2018 at 9:50 PM
    Kelly6773
    Bob
    SC
    18 TRD sport DCLB
    I thought the same as
    You till he said he was only towing 4 x a year or so. If the F150 won’t fit then Tacoma should work. It won’t like it agreed but it’ll do it
  19. Jul 2, 2018 at 9:53 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    If you are going Tacoma get the manual transmission for that kind of load. I would also recommend OVTune for it.
  20. Jul 2, 2018 at 9:56 PM
    kalsonc
    Yep
    I was set of the f150 until I tried to park it in my parking spot
    Neighbours won't be happy since I live in a corner lot and they might hit the truck as they turn in, outside parking is not available sadly
    Tacoma sb fits perfectly and I only tow 4x a year
    I agree it'll be slow but previously when towing with my old f350 I only go 60-65 mph anyways
    Decided to sell the f350 which I only use when towing and my daily drive to have 1 vehicle that can do both (daily and tow)
    So it seems like the Tacoma fits that perfectly
