What's so bad about lift blocks?
Discussion in 'Suspension' started by tacofox, Dec 10, 2013.
  1. Dec 10, 2013 at 1:07 PM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Well to start with, everyone talks trash about them:D
  2. Dec 10, 2013 at 1:12 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    95.5 Tacoma SX.
  3. Dec 10, 2013 at 1:35 PM
    tacofox
    tacofox [OP] Well-Known Member
    Isaac
    MO
    11 reg cab 4x4
    Either way thanks guys, alot
  4. Dec 10, 2013 at 1:45 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    one of the big issues are going to be axle wrap, this is no good.. but if your not going any off road you wont be in much trouble... I do suggest dont try and take off fast with blocks.. this will cause axle wrap quickly.. For the price you pay for a block kit you can get AAL in the rear... yes most aal kits are 2.5.. If your dead set on 3 inches you could do a 2 inch AAL, and 1 inch blocks in the rear... if it was me i wouldnt do a 3 inch block..
  5. Dec 10, 2013 at 3:06 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Would this have happened if the bump stops had been extended?
  6. Dec 10, 2013 at 3:26 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    no it wouldnt have.
    as long as you hit your bump stops before you bottom out your shocks you will be fine.
    the way to test that, is take the coil off of your shock, put the shock back on the truck, and jack up that tire.
    the reason that happened is because by putting a spacer on the top of the shock, it pushes the whole body of the shock down, and makes it bottom out before the bump stop.
  7. Dec 10, 2013 at 3:37 PM
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Another reason not to do the top mount spacers only is that Toyota designed the shock to be the droopstop in the suspension design. If you add a top mount spacer, you are extending the droopstop by the thickness of the spacer. If you go more than a 1/2 inch, the upper balljoint will bind on full droop and the UCA will smack into the coil.
  8. Dec 10, 2013 at 4:21 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Ahhh, now we're getting somewhere on actual info. Most posts I've read have an awful lot of opinion without detail. Good work. Anything else that will cause problems?
  9. Dec 10, 2013 at 5:08 PM
    YOTA LOVER
    NH
    Not really. Anything other than replacing the entire strut with one purpose built to provide lift is garbage, resulting in garbage. All we've been doing is talking about what in the trash bag stinks worse, metaphorically speaking.
    And the issue with blocks in the rear has been beaten to death in a million threads.
  10. Dec 10, 2013 at 5:34 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    :popcorn::threadjacked: ;)
    Op go with the AAL, a 1 inch block isn't really that big of a deal, though I yanked mine out when I purchased my truck used (lifted) and swapped it out for full leaf packs. Can't go wrong with full leaves.
    AAL is also way cheaper than full leaf packs.
    Thanks,
    Brett
  11. Dec 10, 2013 at 5:53 PM
    AirForceTacoma08
    AirForceTacoma08 Well-Known Member
    Adan
    From AZ but Utah living
    08 Taco DCSB
    URD CAI throttle body spacer doug thorley headers straight pipes magnalow muffler URD MAF Sensor Calibrator
    ok so i may a little confused but is axle wrap a risk with front block on the coils or just the rear??
  12. Dec 10, 2013 at 5:59 PM
    metrick1215
    Habersham GA..
    Not on Coils on front, (unless i guess you did a solid axle swap, but dont quote me on that) But you have the risk of breaking your shocks running the "Hockey Puck" style spacers and coil spacers...
  13. Dec 11, 2013 at 9:02 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Bear with me - another couple of questions.
    With ball joint bind; how is using a spacer different from using a full strut replacement in prventing the bind? I can picture the bind due to the frame being higher with a lift but how does a spacer cause bind and not a full spring replacement? Do replacement struts still stop at the same relative location as stock when measured from the top of the stroke meaning they must have added material to the bottom of the strut to make up for the difference in lift?
  14. Dec 11, 2013 at 9:35 AM
    steezemcqueen
    Dylan
    Crawlarado
    With a top plate spacer, the whole shock assembly is being pushed down and the shock is not being extended at all from the lift. Therefore the shock can still fully extend the same distance that it would even if the spacer was not install.
    A preload spacer, the 5100's and taller springs gain lift by keeping the shock assembly in the same position and causing the shock itself to be extended further at ride height.
    Kinda hard to explain but i would recommend to read this info PDF Bilstein did on the 5100's
    http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
  15. Dec 11, 2013 at 9:37 AM
    #35
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Not ideal for offroading, if you like the look of a lifted truck and wont take it offroading youll be fine.
  16. Dec 11, 2013 at 9:55 AM
    #36
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    you will be fine, unless you tow, then you will experience large axle wrap, there are solutions to minimize the wrap with some simple leaf pack addons....
    my recommendation would be at least the AAL, clamp the leafs to minimize axle wrap...
    I added this:
    http://shop.advanceautoparts.com/we...raft_10053624-p?searchTerm=leaf+spring+helper
    Use one of their 30% off coupons, order online and pick it up at your local store, I snagged one for about $23.....there is a thread here at TW that shows the install, very simple, maybe an hour if you takes breaks....
  17. Dec 11, 2013 at 11:25 AM
    #37
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Once you understand what axle wrap is, it will make sense.
    So, imagine your leaf springs - I'm gonna make 'em flat like you have a load in the bed.
    ______________
    Code:
    Now imagine your leaf springs with the axle underneath them:
    ______________
          O
    Now imagine your leaf springs with a block above the axle:
    ______________
          O
    Now imagine you stomp on the gas and the axle starts to rotate:
    _______---------
            O
    Make a little more sense now? :)
  18. Dec 12, 2013 at 11:45 AM
    #38
    AirForceTacoma08
    Adan
    08 Taco DCSB
    thats what i thought they were talking about i was confused when the springs and coils came into the convo. thnx man.
    but in all seriousness i was gonna go with blocks but i see now that it is bad thnx guys
  19. Dec 12, 2013 at 12:47 PM
    #39
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    It's not the end of the world, but there is a right way to do things...and a wrong way to do things. ;) If always drive with a light foot and never go offroad you'd probably be perfectly fine. But..it's one of those things that I think is worth doing right.
  20. Dec 12, 2013 at 7:08 PM
    #40
    Domc20
    Domc20 Well-Known Member
    Dominic
    Baltimore, MD
    2001 Tacoma
    Retro Fitted headlights,HID headlights(80000k),Satoshi Grill Mod, LED tail lights, Magnaflow exhaust , Spectre CAI, 2.5inch spacer lift , Nitto Terra Grapplers 285/70/17, XD Revolvers ,2" blocks rear
    I have 2 inch blocks in the rear and I dont go off road.... my truck rides fine.
