Whats that button to the left from clutch pedal for ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by petyanca, May 8, 2010.
  1. May 8, 2010 at 3:07 PM
    petyanca
    petyanca [OP] Well-Known Member
    bay area
    09 AC 4cyl 4x4 5spd
    I was searching for trailer braking connector under the steering wheel column while trying to install trailer brake controller. I didn' t find it (probably don't have one), but I've noticed a white button next to clutch pedal. I couldn't find it in the manual. Anybody knows what its for ?
  2. May 8, 2010 at 3:22 PM
    motox_315
    motox_315 Member
    Sean
    Sac
    2010 DCLB SR5 4x
    3" truxxx lift
    take a pic and post it
  3. May 8, 2010 at 3:46 PM
    petyanca
    bay area
    09 AC 4cyl 4x4 5spd
    white plastic thing in the middle of the frame
  4. May 8, 2010 at 3:51 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    If you push the clutch in does it touch the button? If so it could be the clutch start button
  5. May 8, 2010 at 3:58 PM
    petyanca
    bay area
    09 AC 4cyl 4x4 5spd
    thats right, i checked there is a tab on the clutch pedal which pushes the button when the pedal is depressed
  6. May 8, 2010 at 4:25 PM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
  7. May 8, 2010 at 11:42 PM
    GWM
    GWM Member
    Glenn
    Texas
    08 Off-Road SR5 4x4
    i believe that is the button that your clutch presses to allow you to turn on the truck. the one the switch by your fog light switch bypasses...
