what's the best 2" lift with the least harshest ride?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DestinTaco, Aug 9, 2011.
  1. Aug 9, 2011 at 9:38 AM
    DestinTaco
    DestinTaco [OP] Well-Known Member
    Destin, Fl
    2011 Silver PreRunner Off Road DC SB
    Challenger tube step, OME 884 Coil, 2" AAL, Weathertech vent visors
    I wondering what would have the softest ride. Just curious. Thanks.
  2. Aug 9, 2011 at 10:59 AM
    DestinTaco
    Destin, Fl
    anyone?
  3. Aug 9, 2011 at 11:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What's your usage and price range? Best riding meaning on road or off road while taking a beating? Your question is too general to get good input from others. Help me help you :D
  4. Aug 9, 2011 at 11:06 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    No lift.
    But if you have the money I would say custom valved KINGS, Icons or FOX shocks
  5. Aug 9, 2011 at 11:09 AM
    Pugga
    Massachusetts
    Damn, jumping right to the good stuff!! I wish I could get a set of Icons or Foxs. :drool:
  6. Aug 9, 2011 at 11:18 AM
    JLee
    Jerry
    Grass valley CA
    Hey he said the softest ride and you can't custom valve 5100's :D
  7. Aug 9, 2011 at 11:19 AM
    DestinTaco
    Destin, Fl
    It would just be for on road driving and I don't want to spend an arm and a leg.
  8. Aug 9, 2011 at 11:24 AM
    JLee
    Jerry
    Grass valley CA
    This is why you need to add all the details in your OP
    This ^ but with aftermarket coils not preloading your stock ones. I think you guys get just about 2" with the 5100's and Eibachs set at 0
  9. Aug 9, 2011 at 11:25 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    bilstein 5100s with eibach coils. billies and the eibachs give you guys 1.6 i believe.
  10. Aug 9, 2011 at 11:32 AM
    DestinTaco
    Destin, Fl
    Thanks. Sorry for the lack of info.
  11. Aug 9, 2011 at 11:32 AM
    Pugga
    Massachusetts
    The best option would most likely be what JLee mentioned but they are very pricey.
    A good option would be new struts with aftermarket coils such as OME or Eibach. OME coils have a softer spring rate and might be a little cushier than Eibachs. I believe to stay in the 2" range, you'd be looking at 884 coils. 885's would put you a little over 2" of lift. Eibachs would give you about 1.6".
    The least expensive option is 5100's up front set at 1.75. This would preload your stock coil to provide lift.
    In the rear, 1.5" 3-leaf progressive AAL with new shocks. Again, depending on what you want to spend, Fox, Icon or King would be best, Bilstein would work and would still ride nice.
    You'd have a firmer on road ride but I think it's a more planted feeling.
  12. Aug 9, 2011 at 11:37 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    does least harshest mean the most harsh? the most least harsh? the leastest most harsh...? :confused:
    :D
  13. Aug 9, 2011 at 11:41 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    eibach coils up front and icon progressive 3 leaf AAL in back with new shocks, prob 5100's
  14. Aug 9, 2011 at 12:13 PM
    colder
    MN
    I'm sure he'll bounce back. But maybe the mods should issue me a suspension.
  15. Aug 9, 2011 at 12:29 PM
    DestinTaco
    Destin, Fl
    LOL, I could have used better grammar.
  16. Aug 9, 2011 at 12:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm shocked!
  17. Aug 9, 2011 at 12:49 PM
    Pugga
    Massachusetts
    :rimshot:
  18. Aug 9, 2011 at 12:56 PM
    colder
    MN
    My confidence has definitely been swayed. I won't be strutting around here so arrogantly from now on.
  19. Aug 9, 2011 at 1:38 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this. eibachs only give you 1.6" though. so add in a 1/2" top plate spacer
  20. Aug 9, 2011 at 4:04 PM
    MJF
    MJF VSC blows
    Peoples republic of Kaliforniastan
    2011 TRD sport DCLB
    I just installed Bilstein 5100 front shocks set on 0 with a set of OME 884 front springs. I feel it is firmer than stock but much less harsh. The stock setup was harsh due to hitting the bumpstops with the soft springs and a lack of proper compression damping. Now the spring rate is much more suitable for a truck and the 5100 provides the correct damping for the spring.
