What's the best Baja suspension and wheels for under $3K
Discussion in 'Suspension' started by Baja2012, Jul 25, 2011.
  1. Jul 25, 2011 at 12:34 AM
    Baja2012
    Baja2012 [OP] New Member
    Baja Sur
    4x4 TRD
    Zero
    New to TW and happy to find you guys.
    I spend 6 months in Baja and wanted to get your guys advice on what Is the best suspension/tires for my 2006 4x4 double cab.
    I bought this truck to tackle Baja and found out last year that the stock TRD suspension left a bit to be desired. Also, I feel I need a lift because I am sick of dragging the freaking mud flaps.
    Budget ~$3,500 for tires and suspension
    Wants:
    To be able to fly down washboard roads at 40 to 60 MPH and not rattle the truck to pieces.
    Try not to kill the gas mileage (reason I bought this truck)
    2 to 3 inch lift and level the truck
    Good in the sand, a must!
    Probably go with the BFG AT, since the have never failed me, but not sure what size?
    Thanks for your help and advice!
  2. Jul 25, 2011 at 1:01 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    King oem replacement resi shocks, front/rear, some method racing rims and treadwright guard dogs 33"
  3. Jul 25, 2011 at 1:03 AM
    kinkrider101
    santa barbara
    wheels and tires
  4. Jul 25, 2011 at 1:35 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Id say replacements coilovers and rear pack with rear shocks with resi's basically a mid travel kit, with as you mentioned BFG AT 285/75/ basically a 11.5" 33" tire.
  5. Jul 25, 2011 at 10:28 AM
    Baja2012
    Baja Sur
    4x4 TRD
    Zero
  6. Jul 25, 2011 at 11:27 AM
    Baja2012
    Baja Sur
    4x4 TRD
    Zero
    Ok, King's front and back it is. However, they recommend 265/75. I am pretty sure I want a bit larger tires than this. 275 or 285.
    Should i upgrade the wheels later to save some cash now, or just bite the bullet and replace the wheels and tires now? Thoughts on what this will do to my Gas mileage?
    Should I stay with the stock 16" wheels? Benefits to 17"? If I buy new wheels should they be 16" or 17"?
    Thanks for your guys help!
  7. Jul 25, 2011 at 11:29 AM
    kinkrider101
    santa barbara
    wheels and tires
    Stay with the stock 16s if you like them, If you want 33s you will need to run a spacer in the front
