What's the best drain plug gasket material?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Feb 1, 2009.
What is the best oil plug gasket material?
Poll closed Feb 6, 2009.
  1. Nylon
    14.8%
  2. Rubber
    7.4%
  3. Copper
    11.1%
  4. Crushable aluminum or copper
    22.2%
  5. Metal/Rubber
    11.1%
  6. Fiber
    33.3%
  1. Feb 1, 2009 at 4:19 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    12mm and ......rubber, nylon, fiber, crushable, copper, aluminum, metal/rubber?
  2. Feb 1, 2009 at 4:21 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    I used the one in the plastic tub next to the register @ the dealership (I use OEM oil filters).
    I think the last tub was full of nylon ones.
    EDIT -I once used a fiber one, maybe from Checkers/Kragens....came in the little red package.
  3. Feb 1, 2009 at 4:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    either crushable or as i have seen on the new tacomas.....the gasket/washer was a weird kinda material, but it worked thru 3 or 4 oil changes just fine.............and i think it may have been fiber.
  4. Feb 1, 2009 at 4:24 PM
    Snyperx
    Snyperx Seniore Marcos
    OEM washer, whatever that is made of.
  5. Feb 1, 2009 at 4:33 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I put this poll up because my 2006 had no washer on the oil drain plug.
  6. Feb 1, 2009 at 5:14 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I still have the original gasket on my 2000 echo with 235,000 miles on the car.
    NO LEAKS!!
    You're wasting your money..........
    Marc M
  7. Feb 1, 2009 at 5:31 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I think it's a waste too, but I need one between my Fumoto valve and the pan....
  8. Feb 1, 2009 at 5:33 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    SInce it will be the last one need, I am going with copper.
  9. Feb 1, 2009 at 6:14 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Recycled Nissan Frontier metal would be the best choice.
  10. Feb 1, 2009 at 6:55 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    But then I would have to deal with rust and gook and stuff.
  11. Feb 1, 2009 at 7:14 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^This is a good point. Using your theory, maybe we can use the metal of retired Corolla's or Camry's.
  12. Feb 2, 2009 at 5:58 AM
    Bassetdad
    Bassetdad What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    After 99,500 miles, I still use the orginal gasket that came with my 2001.
  13. Feb 2, 2009 at 8:03 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    What's the OEM ones made out of?
  14. Feb 2, 2009 at 8:14 AM
    rachunter
    rachunter Well-Known Member
    West Virginia
    08 TRD Off-Road
    XM Radio,Access Lorado Tonneau, Ventshades, Tinted Windows, Destination A/T's , Moto Metal wheels and lots of Liquid Glass
    I'm on my third Tacoma and I have never replaced the factory washer on any of them and I have yet to have my first oil leak.
    So I would say whatever the factory uses is hard to beat.
  15. Feb 2, 2009 at 8:28 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    it comes with one on it.
    I replace the crush washer each time from the dealer and save the receipt. I write down the mileage on there as "proof" that I changed my oil.
  16. Feb 2, 2009 at 1:14 PM
    rachunter
    West Virginia
    08 TRD Off-Road
    That proves you bought a crush washer, it in no way proves you changed your oil.
    But....
    I worked in the car business for years and honestly if something needs repaired under warranty it will be repaired because the customer cannot prove they changed oil and the dealership cannot prove the customer did not change oil. It ends up being a non-issue and the warranty will be honored.
  17. Feb 2, 2009 at 1:31 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I know, but it is better than nothing. I save the receipts for the oil filter and oil and write down the mileage on the them.
  18. Feb 2, 2009 at 5:53 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Black RTV.
  19. Feb 3, 2009 at 4:49 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    As others said oem stock material whatever the heck its made of so there you go
  20. Feb 4, 2009 at 9:56 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Found this good info on the Fumoto web site that answers my last questions:
    If you are using the Engine Oil Drain Valve on off-road vehicles such as farm tractors and logging equipment under extreme environment (i.e. corn fields, brush areas), it is recommended that a hose clip as shown below be used for extra safety and security. The hose clip, which can be purchased at any hardware stores, will firmly keep the lever in the locked position at all times.
    Drain Valve SizeHose Clip SizeT, FG Series11/16" ClipF Series5/8" Clip
    Q.Does my Engine Oil Drain Valve protrude into the interior of the oil pan and prevent full drainage of my engine oil? A.No. The threaded oil drain plug hole is always reinforced to accept the threaded bolt of the drain plug. Your Engine Oil Drain Valve will not extend past this threaded portion of the drain hole and will allow the oil to be properly drained. Your Engine Oil Drain Valve will let you drain your engine oil while it is hot without burning your hands and it is much more effective than trying to pump the oil out from above.
