What's the BEST driveshaft slip joint GREASE?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nujerzidevil, Sep 10, 2014.
  1. Sep 10, 2014 at 2:25 PM
    nujerzidevil
    nujerzidevil [OP] Well-Known Member
    NJ
    2011 TRD Sport
    5100's OME 885x TSB - ICON 3 leaf AVID BOLT ON SLIDERS SCS SR8 HANKOOK MT 285/70/17 Tepui Kukenam RTT mounted on ATO bed bars
    Right now I am using Ford Motorcraft XG8 blue Teflon grease. I was told it was the best...yes it gets rid of my thump, but I have to re grease every oil change. Grease seems to last aprx 3,200 miles before it starts to bind again.
  2. Sep 10, 2014 at 7:39 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I prefer a marine grease.
    I know the zerk fitting is the easy method but feel every other time you still would need to pull out the shaft and spray it down with brake cleaner and then apply new grease to a clean surface.
    Tranny fluid is a detergent and washes away the grease slowly.
    Mine has last way over 3K since I have grease mine, probably at 8-10K.
    Adding new grease to older grease that is breaking down is not a good idea.
