What's the best mod I can do for $20? Ready...GO!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jerneyman, May 14, 2016.
  1. May 14, 2016 at 11:37 AM
    jandrews
    '09 FourDubDee TRD OR
    The $10 I spent to put extra d-rings in the bed has probably been more valuable to me than the rest of the mods I've done to my truck combined.
  2. May 14, 2016 at 11:57 AM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
  3. May 14, 2016 at 8:44 PM
    ISLANDJIM
    ISLANDJIM Well-Known Member
    2017 4Runner Off Road
    Where you get D-rings for $10??
  4. May 14, 2016 at 10:25 PM
    jandrews
    Army surplus rings.
  5. May 16, 2016 at 11:38 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    did you put them on the floor of the bed or the sides
    VermontTaco likes this.
  6. May 16, 2016 at 12:04 PM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    Ordered a set last week myself. I went a little more expensive after the reviews, but I think this is a solid addition. When they left the factory they did not leave us with much as far as options for securing cargo to the floor. http://www.ebay.com/itm/201562334612 I am going to add four to the floor and two to the vertical panel next to the tail gate: https://www.tacomaworld.com/threads/installed-d-rings-in-the-bed-pics.28533/page-17#post-5014134
    As far as OPs question: organizer for the center console, LEDs for the interior, backup LEDs for the reverse lights, etc.
    IronPeak likes this.
  7. May 16, 2016 at 12:27 PM
    Hashc93
    Hashc93 Well-Known Member
    DrFunker[QUOTED] likes this.
  8. May 16, 2016 at 12:59 PM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    extra d rings and the bar caddy are must haves in that price range. Used the oem rings and mounted as in the instructions for a short bed, on the sides.
  9. May 16, 2016 at 4:22 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ES Radiator bushings.
  10. May 18, 2016 at 2:45 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    where did you get the rings? So they are the ones on the sides of the bed, correct?
  11. May 18, 2016 at 9:12 PM
    jandrews
    No. Bed bolt mount method. Got mine from army surplus.
  12. May 18, 2016 at 11:44 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    LED Bed Lights. You can buy a roll on Amazon for around $10...add a small switch and you be good to go. Handy with or without a shell.
  13. May 18, 2016 at 11:59 PM
    SoCal_Yotas
    SoCal_Yotas Well-Known Member
    Elias
    Santa Clarita
    2015 Toyota Tacoma TRD-Sport 4x4
    I'm intrigued...write up?:D
    DustStorm4x4 likes this.
  14. May 19, 2016 at 12:39 AM
    eon_blue
    Azusa, CA
    $20 toward a softopper
  15. May 19, 2016 at 5:23 AM
    #35
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I don't have a write up, as I found it on here by someone else, but its simple.
    I used this USB charger http://smile.amazon.com/Foxnovo-Por...&redirect=true&ref_=oh_aui_detailpage_o05_s00
    Pulled the center console, drilled a hole, popped the charger in, and put on the locking nut.
    Ran a ground wire from the charger to one of the bolts under the center console where other grounds were (I used a quick disconnect on the wire, just in case I have to pull the center console, that I don't have to cut the wire)
    Ran another wire from the charger through the center console, under the dash to the fuse box. Connected an Add-a-fuse to the end of that wire, then plugged it into an existing fuse. I chose the cig lighter/accessory fuse, figuring if I blew it somehow, it wouldn't cripple the truck, and that it turns off when the key is removed.
  16. May 25, 2016 at 11:11 AM
    #36
    ejl923
    Eric
    Western Mass
    Sorry for the delay, wasnt getting updates. Bought them on Amazon, yes they are the ones on the side
  17. Jun 4, 2016 at 6:35 PM
    #37
    ISLANDJIM
    Didn't like the black plastic satellite antennae that came on my 2015, noticed the older pancake style antennae were color matched to the bodies of the trucks. Toyota was trying to save a few pennies obviously.
    Free for me mod as I already had the white epoxy appliance paint, painters tape, newspaper and sandpaper.
    Set your razor knife for minimum depth and apply painters tape and newspapers around the base of antennae and cut the tape in between the black gasket and the antennae. A non-windy day is best for this. Take some sandpaper and rough up the finish on the antennae, a fine to medium grit will do. Clean with rubbing alcohol and let dry a few minutes and apply a couple coats and your done.
    Thank goodness white is so easy to match. if you have an off color it may be hard to match it up.
  18. Jun 4, 2016 at 7:04 PM
    #38
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    This.
    Crom[QUOTED] likes this.
  19. Jun 17, 2016 at 6:43 PM
    #39
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Tag in for some great info
  20. Jun 17, 2016 at 6:45 PM
    #40
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Sell jt and get A little over .25 tank gas. Or drive and get beer or liquor and chill at home.
    t4daddy likes this.
