Whats the best order to do all this brake work?
Discussion in 'Technical Chat' started by J89, Aug 8, 2019.
  1. Aug 8, 2019 at 9:48 AM
    J89
    J89 [OP] Active Member
    Vancouver
    07 DCLB
    So I'm going to be replacing pads, rotors, calipers and drum brakes on my 2007 tacoma. Also going to be flushing the brake fluid.
    Wondering what would be the best order to do all of this.
    Maybe everything at once except drum brakes and save that for another day?
    As far as flushing out the old brake fluid, maybe leave it in there until I replace the calipers then do a flush then since some will be coming out during that swap anyway?
    Any tips?
    J
  2. Aug 8, 2019 at 9:29 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    all at once, the front brakes take maybe an hour and the rear maybe another hour tops. Flush the fluid once you're done replacing the brakes.
  3. Aug 9, 2019 at 1:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your asking is this your first time??
    Do what your comfortable with.
    Anymore getting the wrong parts from the parts store the first time almost seems normal at times .
    What about the Rubber hoses and hardware kits ??
    It takes me lots longer then an hour to do disc brakes on a new vehicle to me just getting the pins out .
    The joy of living in the liquid brine belt
    PzTank and 6 gearT444E like this.
  4. Aug 9, 2019 at 2:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Seems like you may not be experienced at this?
    My tip would be to get an experienced friend involved. Even if all they did was look over your shoulder to coach you a bit, then assist you with the bleeding process.
    All done, go out for a brake bedding run, and while out, buy them a nice lunch.
    It will be worth it.
    Wyoming09, Lester Lugnut and PzTank like this.
  5. Aug 10, 2019 at 3:40 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I gotta say looking at those rear brakes the first time with the parking brake linkage can be a little scary
  6. Aug 10, 2019 at 3:48 AM
    Taco man17
    Taco man17 Virginia Good Ol' Boy
    Mark
    Tacoma TRD off-road 2017
    Truck cap , husky liners, deflector shield, ARE truck cap.
    Use your smartphone and take pic of the rear brakes before disassembly .
  7. Aug 10, 2019 at 7:21 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I was thinking in the days before Smart Phones.
    I have yet to get one but the one work gives me no cell service at home
  8. Aug 11, 2019 at 5:58 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I would do the rear brakes on another day. Pads, rotors calipers and a flush is plenty for one day IMHO.
  9. Aug 11, 2019 at 6:03 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    One wheel at a time so you can reference the one on the other side if you forget how it goes together. I'd probably flush it last.
    I would start with the fronts, they're generally the quickest and easiest. But if you're feeling ambitious, jack up the rear at the same time, pull the rear wheels and soak the spots where the drums meet the studs with pb blaster, that'll make it easier to get the drums off later.
  10. Aug 11, 2019 at 6:06 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Just a note; if you get air in your ABS it can take a professional with specialized equipment to bleed the air.
