What's the best way to burn discs for Toyota WMA/MP3 player
Discussion in 'Audio & Video' started by HBMurphy, May 14, 2010.
  1. May 14, 2010 at 11:04 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    What's the best way to burn these discs? What structure for the files?
    TIA!!! :)
  2. May 14, 2010 at 11:09 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    windoze media player and .wma always works for me.
  3. May 14, 2010 at 11:36 PM
    HBMurphy
    Paul
    So California Coast
    None
    Thanks
  4. May 18, 2010 at 10:51 PM
    HBMurphy
    Paul
    So California Coast
    None
    used that and no luck any other ideas? Can I just burn a data disc? What should the file structure look like?
    thanks in advance!
  5. May 19, 2010 at 5:15 AM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    It shouldn't matter. When I still had the factory head unit I used both burned audio disks and data disks and they all worked fine. The folder structure I used for data was the same one Windows Media Player uses to store songs. I just drag and drop and go.
  6. May 19, 2010 at 5:20 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yes, just burn data disc but with .mp3 files. They are compressed more than .wma files are and more will fit on the disc. The other thing to make sure you do is finalize the disc where no more files can be added later (can't do that anyway unless disc is CDRW. CDR discs are 1 time burn) If you do not finalize it other devices won't be able to read disc. There should be an option for this to be checked or unchecked somewhere before you click burn. Might have to click more at the bottom of the software to see those options depending on your burning software.
  7. May 19, 2010 at 7:25 AM
    HBMurphy
    Paul
    So California Coast
    None
    Thanks guys! - Last night I used roxio and burned a "Jukebox" disc and everything worked fine... I wonder why the one I burned on WMP didn't work - Oh well, everything is good today!
