What's the best way to prep wheels before mounting?
Discussion in 'Detailing' started by 2013XSPX, Sep 3, 2021.
  1. Sep 3, 2021 at 2:59 AM
    2013XSPX
    2013XSPX [OP] Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Hey TW!
    When putting new wheels on fresh out of the box what should you do beforehand to ensure they stay looking as best as possible and clean up as easily as possible? I'm open to DIY and also dropping off. I'd appreciate hearing what you all do. Thank you!
  2. Sep 3, 2021 at 5:06 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    As much as I agree with your desire to pre-prep your brand new wheels before mounting, I might suggest pumping the brakes just a bit.
    First, of all, I'd recommend ceramic coating them for ultimate protection. Wheels take a beating and conventional waxes just don't hold up. That said, I'd hold off on any kind of protective coating until after the wheels have been mounted and balanced. Why? Because if you use self adhesive weights - which almost everybody does these days - they may not stick to your nicely coated surface. That would be a bigger problem.
    wmb67 and 2013XSPX[QUOTED][OP] like this.
  3. Sep 3, 2021 at 5:20 AM
    2013XSPX
    GA/FL Border
    2013 XSP-X
    That is an excellent consideration. I didn't even think about that. Okay! So after mounting....what's the best course of action? Anything specific to know about ceramic coating wheels?
  4. Sep 3, 2021 at 5:39 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Lubrication before mounting!
    2013XSPX[QUOTED][OP] likes this.
  5. Sep 3, 2021 at 8:07 AM
    Too Stroked
    Tom
    Depending on the pattern / machining / finish of the wheel you choose, wheels can be a royal paint to coat. No matter what, the key is a perfectly clean and corrected wheel. Another consideration is which ceramic coating to use. You want something relatively easy to use. I generally use CarPro CQuartz UK 3.0 these days.
  6. Sep 3, 2021 at 9:08 AM
    2013XSPX
    GA/FL Border
    2013 XSP-X
    I was considering this:
    Too Stroked[QUOTED] likes this.
