What's the best Wheel Cleaner....for brake dust...???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Werloc, Apr 3, 2010.
  1. Apr 3, 2010 at 7:30 AM
    Werloc
    Werloc [OP] Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Looking for a really good wheel cleaner to remove the tuff brake dust. My wheels gotta look new again.
    What do you think?
  2. Apr 3, 2010 at 7:31 AM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    Castrol Superclean works great.
  3. Apr 3, 2010 at 7:46 AM
    Werloc
    Bob
    Central, NJ
    You think Pep Boys would carry that?
  4. Apr 3, 2010 at 8:00 AM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    i would think so i know walmrt has it. i usally buy a gallon and put it in a spray bottle.
  5. Apr 3, 2010 at 8:31 AM
    lb86
    lb86 rookie
    Pensacola
    White 06 Prerunner Reg Cab
    wesley's tire/wheel cleaner. i use it on mine and it takes dust and dirt off i didn't even know was on the wheel in the first place.
  6. Apr 3, 2010 at 8:44 AM
    Werloc
    Bob
    Central, NJ
    Then they aren't dirty. Mine are aluminum and black from brake dust. I need powerful stuff here.
  7. Apr 3, 2010 at 8:50 AM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    i always scrub them with a stiff bristle brush and soap and water, then powerball the crap outta them with some aluminum polish then wax.
  8. Apr 3, 2010 at 9:54 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Simple Green (Undiluted). Cuts the crud on wheels, and cleans the tires very well too. Doesnt harm alum wheel finish/cleacoat
  9. Apr 3, 2010 at 12:05 PM
    BigJimHouse
    BigJimHouse Member
    Jim
    Kauai
    Napa has some brutal stuff called Aluminum Brightener or something like that (also says Mac's on the Napa spray bottle). Works great but be CAREFUL. Nasty acid type stuff! Gotta be armed with the garden hose at the same time!
    Best stuff I've ever seen come out of a spray bottle.
    Jim
  10. Apr 3, 2010 at 5:39 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    purple power right out the bottle works awesome, on tires too
  11. Apr 3, 2010 at 6:52 PM
    Werloc
    Bob
    Central, NJ
    I have the same wheels you do. Are they clear coated? I don't think mine are because the brake dust is only staying where it's pitted some. It's not "to" bad, but I really want them perfect, since my new 03 is clean as hell.
  12. Apr 3, 2010 at 7:04 PM
    Slapps74
    Slapps74 Well-Known Member
    Thornton
    2014 FJC
    Bone stock for now!
    TIME OUT! what kind of wheels? Steel or alum, polished or clear coated.
    Some of the stuff in other posts will destroy yor wheels. Try some thing a little less harsh and a little elbow grease. I think it's made by Meguires and it called A to Z wheel cleaner. Try that first. If you get lucky you can catch a parts jockey at Auto Zone or Checker that can find his A$$ with both hands and they can put you on the right path.
    FYI- Aluma bright is NASTY stuff and for semi wheels.
    Good luck
    Slapps
  13. Apr 3, 2010 at 8:40 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Brake cleaner is the best thing I have found. But it will probably take off paint.
  14. Apr 3, 2010 at 8:43 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    Meguiar's Wheel Cleaner, the one in the purple bottle, did wonders on my Taco and in an X5 which had wheels with 2 year build up brake dust.
    Fuck... I should probably get hired as a Meguiar's spokesperson for how much I use their products...
  15. Apr 4, 2010 at 1:28 AM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    Simple Green works wonders!
    Try that!!
  16. Apr 4, 2010 at 12:56 PM
    BigJimHouse
    BigJimHouse Member
    Jim
    Kauai
    Aluma bright works fine, (why I said to be ready with the hose!), also reading the directions helps.
    I've used it on different aluminum items (none clearcoated) with awesome results, spray on, hose off after 5 seconds and proceed after seeing what results you're getting.
    Jim
  17. Apr 4, 2010 at 1:19 PM
    ak47
    Anthony
    Washington
    stock 2nd owner
    im not sure but if i were to guess i would say no.
    i just use car soap and scrub them really good then use a little of this
    the first time i did it i took all the wheel off the truck (i needed to rotate them anyways) and used quite a few coats of it. took me awhile but its good stuff.
  18. Sep 23, 2010 at 2:31 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    Black Magic Titanium wheel cleaner works well, and really holds a shine
  19. Sep 23, 2010 at 2:43 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I asked the same question here and a Detailer Guy named Hans something says Meguires Hot Rims is the best I dont use it but its on sale at Walmart now,theres 2 dfferent kinds ones for standard rims and the others for Chrome rims so read the label
  20. Sep 23, 2010 at 2:46 PM
    Dave333
    Dave333 Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    WD40. Spray it on a rag and wipe it on. I heard this on a motorcycle forum, since the rear wheels are always a PITA to get clean with all the grease and brake dust on them. Crap comes right off and it leaves a nice film to keep other stuff from sticking.
