What's the best year for the second gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Itchyfeet, May 13, 2018.
  1. May 15, 2018 at 6:49 AM
    #81
    Mclovin80
    Mclovin80 Not Well-Known
    Tampa, FL
    2021 LR TRD Pro
    2015 was the best model in my opinion, but there was not much difference in the last few years of the 2nd gen. Last model year of a generation is usually the best year. Normally most of the issues are figured out right in time to create a new generation with new issues. Whatever you do, stay away from the first model year of a new generation.
    Jastoy and JayRolla like this.
  2. May 15, 2018 at 6:49 AM
    #82
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    That's not pyrite mica. Lol
    This is pyrite.
    WoodsGhost, bluezzy and Kuntrykid like this.
  3. May 15, 2018 at 6:52 AM
    #83
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    08, last year for no traction control and mechanical limited slip :burnrubber:
    Ladebakk, Kuntrykid and JayRolla like this.
  4. May 15, 2018 at 6:57 AM
    #84
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    I've had no issues with my pump on my 2013 after 100k. I remember seeing a thread were someone found a dorman (i believe) replacement, that was a lot cheaper and may be more reliable. Am i dreaming this up?
  5. May 15, 2018 at 7:00 AM
    #85
    JayRolla
    Colorado Springs
    Nothing Dorman is more reliable IMO. I think oem is $500-$600. Used to be $1000 or something Cray.
    I highly suggest you do the uni-filter mod or at least inspect the foam internal filter.
    Mine was soft. The ones that fail are hard and brittle. Maybe region and weather had something to do with the foam getting hard.
  6. May 15, 2018 at 7:13 AM
    #86
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I drove my 05 Tacoma for 13 trouble free year's. Not a single issue, no check engine light, no weird noises. Oil, gas, that's it. I was going to get a 16, but wanted to see the initial impressions. The issues on the 16 started pretty fast. I gave it 2 years for them to sort stuff out and purchased an 18. Super happy with it.
    dborrer and Mclovin80[QUOTED] like this.
  7. May 15, 2018 at 7:13 AM
    #87
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Real happy with the 2014 Sport. Almost bought a 2015 but Carmax gave me a much better deal than the Toyota Dealership, which had been backed into on the lot and now had a wreck on its history. Stoked with the lower miles and color too, although price was priority. Bought mine with about 27,000 miles, super clean, and a 75,000 mile warranty for $6 extra on the monthly. Saved about 8k.
    Like the sharper lines on the later 2nd gens too.
  8. May 15, 2018 at 7:16 AM
    #88
    Zacowacko
    Zack
    SW, OK
    I'd still try the dorman if these failed. Couldnt be any worse than the rate these fail at.
    JayRolla[QUOTED] likes this.
  9. May 15, 2018 at 7:21 AM
    #89
    JayRolla
    Colorado Springs
    That is true. Might as well try. I installed a Dorman heater check valve 4runner and is already leaking cuz I could not wait for oem. Less than a year. Never again.
  10. May 15, 2018 at 7:40 AM
    #90
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Not true man. The valves fail due to moisture.
    JayRolla[QUOTED] and TACOVRD like this.
  11. May 15, 2018 at 7:47 AM
    #91
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    True - moisture corroding the valves (reason for the extended run cycle) and the foam disintegrating are the two reasons for pump failure.
  12. May 15, 2018 at 7:52 AM
    #92
    Tractor Dave
    Tractor Dave Well-Known Member
    South Jersey
    2015 Special Addition Off Road SR5 Black
    2.5 Lift,Special Order Truck
    Your absolutely correct, my mistake!!! Can't remember Crap anymore,What was the Silver anyway?
  13. May 15, 2018 at 7:53 AM
    #93
    Tractor Dave
    South Jersey
    I also approve of your rims, you have good taste!
  14. May 15, 2018 at 7:54 AM
    #94
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Silver sky metallic I believe
  15. May 15, 2018 at 7:56 AM
    #95
    viv1d
    viv1d Active Member
    Youngsville, La
    2013 DCSB TRD Sport 6spd
    2013 the best hands down
    Matajramon and TACOVRD like this.
  16. May 15, 2018 at 7:58 AM
    #96
    Tractor Dave
    South Jersey
    Thanks!
  17. May 15, 2018 at 7:58 AM
    #97
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    ‘13 :D
    Matajramon, viv1d and TACOVRD like this.
  18. May 15, 2018 at 8:00 AM
    #98
    Tractor Dave
    South Jersey
    Did you take your center caps off?
    bluezzy likes this.
  19. May 15, 2018 at 8:04 AM
    #99
    Tractor Dave
    South Jersey
    Ok trying this again, did you take off your center caps?
    bluezzy and JayRolla[QUOTED] like this.
  20. May 15, 2018 at 8:05 AM
    #100
    JayRolla
    Colorado Springs
    Yeah NO center caps. I don't like the look of caps.
