What's the big deal with the rear e locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eagle Rock, Aug 6, 2020.
  1. Aug 6, 2020 at 8:19 PM
    Eagle Rock
    Eagle Rock [OP] Well-Known Member
    I have a 2004 very loaded 4x4 taco that is extremely capable in any terrain.
    Every now and then I will talk with another Tacoma owner and they always ask "does yours have the E Locker..diff locker" ...whatever it's called.
    I dont have it but what am I missing out on ?
    Is it a big deal?
  2. Aug 6, 2020 at 8:23 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    If you don't have it and have no problems wheeling the terrain you wheel then it's not a big deal.
    But, you're obviously not wheeling very hard terrain if you don't understand why a locker is very useful.
  3. Aug 6, 2020 at 8:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rear locker is very useful
    Front and rear lockers are even better :drool:
  4. Aug 6, 2020 at 8:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Makes both real wheels spin together, instead of all the power going to the one with the least traction. Handy offroad.
    Hamer95USA and TengoTaco like this.
  5. Aug 6, 2020 at 8:37 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
  6. Aug 6, 2020 at 8:39 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Technically; 4x4 with open diffs is only 2wd. A locker makes it a 3wd truck, I’d argue it’s 50% more capable.
    Ritchie, SR-71A, paetersen and 4 others like this.
  7. Aug 6, 2020 at 10:26 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    One of those things if you don`t have you never depend on the way I look at things
    JJ04TACO and doublethebass like this.
  8. Aug 6, 2020 at 10:29 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a nice extra tool in the bag of tricks. Usually its used when really off kilter and the rear axle has one tire with zero traction.
    It's also nice to engage prior to a crazy challenge, as it reduces the speed needed to get through.
    Aardvark13 and Gunshot-6A like this.
  9. Aug 6, 2020 at 11:06 PM
    02hilux
    Planet: EARTH
    Imagine adding a crawl box to that combination. Its deadly...
    Ritchie, QMEDJoe, Wulf and 1 other person like this.
  10. Aug 6, 2020 at 11:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Now you're just making this thread unsafe to view at work :drool::drool::drool:
    RoughRder, otis24, QMEDJoe and 2 others like this.
  11. Aug 6, 2020 at 11:17 PM
    02hilux
    Planet: EARTH
    what about a custom set of front and rear diamond axles on links, fox 2.5 14" c/o...... too much tacop0rn??
    Ritchie likes this.
  12. Aug 6, 2020 at 11:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :stayontopic:
  13. Aug 6, 2020 at 11:54 PM
    02hilux
    Planet: EARTH
    Been off topic when you mention front locker when OP ask about rear locker, lol
    :burnrubber::deadhorse:
    Kwikvette[QUOTED] likes this.
  14. Aug 7, 2020 at 6:53 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  15. Aug 7, 2020 at 7:28 AM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
    Your use of the word "any" is limited if you've not found a place where a locker would be useful.
    DJB1 and Bannerman like this.
  16. Aug 7, 2020 at 7:42 AM
    Iceberg
    Iceberg Well-Known Member
    Josh
    Alabama
    2008 DCSB TRD OR
    IMO a locker is probably the best upgrade you can do to your truck to make it more offroad capable. Good tires are up there too but locker will allow your truck to make it through more obstacles and at a controlled pace. I don’t use mine that often but it has gotten through or out of situations I would have been stuck or damaged the truck badly had I not had it. It is not for everyone but if you get your truck in hairy situations I wouldn’t be without it.
    Hamer95USA and Ritchie like this.
  17. Aug 7, 2020 at 8:05 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Exactly. I use it to take the drama out of climbing something even mildly challenging for the wife. It eliminates having to hit the gas and brake and hopping that can make her nervous. I even used it while wheeling on wet roads in the Alpine loop. The drop offs really made her nervous so I locked the wheels for less chance of spinning and her shitting her pants.
    For me all that wheel hop = stress on the drive train and axles. So I use it sometimes even when it's not really needed.
  18. Aug 7, 2020 at 8:13 AM
    campoman45
    campoman45 Well-Known Member
    Al
    96 tacoma 4x4 extra cab
    headers, warn winch, Detroit lockers 2 inch lift
    I agree I have front and rear lockers on my 95 , its unbelievable where this truck will go with lockers , but my rule of thumb is go in in 2 wheel drive with a rear locker if you get in a bad situation turn in those front hubs and more then likely you can get out , a winch is also a good idea if everything else fails
  19. Aug 7, 2020 at 8:17 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I hardly ever use my locker in the warmer months. Mines sees the most use when the snow falls and it gets deep and crusty.
    Locker + Chains + High rpm = do what I want
    RoughRder likes this.
  20. Aug 7, 2020 at 8:18 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    Does anyone have a good working link on the Gray Wire Mod?
