What's the big deal with the rear e locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eagle Rock, Aug 6, 2020.
  1. Aug 8, 2020 at 10:09 AM
    #41
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Yep, As far as wheeling goes. Y'all have everything else right at your fingertips for every day living.
    You're a lot closer to Colorado then I am and that's where its at for wheeling! :mudding:
  2. Aug 8, 2020 at 10:14 AM
    #42
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The first/second gen elocker is actuated by an electric motor and gear/rack system housed outside the diff and not a solenoid. This makes it much more susceptible to contamination and just simply wadding up without regular use, so yes, always actuate it as much as possible.
  3. Aug 8, 2020 at 11:28 AM
    #43
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Me too. On my third round of complete fluid changes including rear end, the latest done about 6000 miles ago.
  4. Aug 8, 2020 at 11:40 AM
    #44
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    My prerunner has an e locker and it makes a world of difference when in mud and sand not as good as if I had the extra front wheel helping
  5. Aug 8, 2020 at 1:17 PM
    #45
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    it was the first video that "explains" the idea of open diffs and how the locker/transfer works for the majority of us (me even). But I do see what you mean in regards to speed (rotational output?) vs the actual torque being applied:
    LOCKED DIFFERENTIAL:
    The locked or locking differential is a variant found on some vehicles, primarily those that go off road. It is essentially an open differential with the ability to be locked in place to create a fixed axle instead of an independent one. This can happen manually or electronically depending on technology in the vehicle.
    The benefit of a locked differential is it is able to gain a considerably greater amount of traction than an open differential. Because the torque is not equally split 50/50 it can channel more torque to the wheel that has the better traction - and is not limited by the lower traction of the other wheel at any given moment.
    Because you are unlikely to be travelling at speed and are usually travelling over uneven ground, the issue of tire drag and wear around corners on a fixed axle is less of a problem.
    One disadvantage of locked diffs is called binding, which occurs when excess rotational energy (torque) is built up within the drive train and needs releasing – typically achieved by the wheels leaving the ground to reset the position. Or by simply releasing the locks once they are no longer needed.
    Imagine a long cardboard tube held at each end, and then twisting the tube in opposite directions to the point the tube couldn’t withstand the force anymore and folds and tears – that’s binding. It happens because the wheels are moving at different speeds which twists the axles and puts increased pressure on the gears - but the load on the wheels and their increased traction is enough to prevent the tires slipping to release the pressure.
  6. Aug 8, 2020 at 4:09 PM
    #46
    1 Honey Badger
    1 Honey Badger Active Member
    Calimesa, CA
    2001 Tacoma TRD
    I have an e-locker and before today, I’ve used it once in three years in the snow. Well, today I took a wrong turn while off road and drove down a rocky hill that came to a dead end. I was slipping and sliding in 4lo trying to get back up that hill, before I hit that magical button that saved my butt. Before today I would have said it’s something I could leave or take. After today, I’m so damm happy I have it or I would still be stuck in the middle of nowhere.
    Truckstop13, cruiserguy and QMEDJoe like this.
  7. Aug 8, 2020 at 4:44 PM
    #47
    QMEDJoe
    Joe
    This is why me needz dual lockers.
  8. Aug 9, 2020 at 10:36 AM
    #48
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    cruiserguy and Wulf like this.
  9. Apr 7, 2021 at 2:48 PM
    #49
    802 taco
    802 taco Member
    2016 dclb sr5
    Fox 2.5 coil overs Spc control arms fox 2.0 remote res rear ome med duty lead pack Cali raised sliders rci full skid
    Just got my two new diffs from ecgs can’t wait to test out the taco locked front and rear these trucks will get through some nearly shit open open I know I have but the 6 times I was stuck last year I bet maybe only one of those times I would of been stuck locked !!
