What's the biggest the 2nd gens can go without adding a lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ne0tas, Feb 29, 2012.
  1. Mar 1, 2012 at 12:30 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    You can clear 265/75-16 on stock suspension
  2. Mar 1, 2012 at 12:37 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    hahaha...some of these people actually believe you, that's the best part.
    LT height is usually lower sitting static.
  3. Mar 1, 2012 at 12:39 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Droop travel ftw
  4. Mar 2, 2012 at 6:54 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    There is no reason whatsoever that I could not bolt on stock suspension components and STILL clear 37's. Yes, I'm running long travel, but I removed the coilovers and fully stuffed the front tires, then turned the steering wheel lock to lock. Anything that the tire rubbed on got chopped or beat on enough that it clears. Look at my sig pic, the front end is stuffed and there is no rubbing. I could fit 37's on an xrunner with a sledgehammer and a sawzall.
  5. Mar 2, 2012 at 9:45 AM
    TeamBosing
    TeamBosing Active Member
    or do not open or comment in a thread if you don't like it! :rolleyes:
  6. Mar 2, 2012 at 9:45 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    275/70/17s
  7. Mar 2, 2012 at 9:57 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe
