What's the deal with this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zuckdan, Mar 5, 2011.
  1. Mar 5, 2011 at 3:42 PM
    zuckdan
    zuckdan [OP] Well-Known Member
    Evergreen CO
    2011 DC SR5
    Been enjoying my 2011 DCMT for about a month. Noticed these a couple weeks ago. Passenger front wheel well has little vents cut into engine compartment. Drivers wheel well is just normal smooth plastic. Anyone know if all 2nd gen have this and what its for?
  2. Mar 5, 2011 at 3:43 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My 05 has it.. Not sure why.
  3. Mar 5, 2011 at 3:44 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Air intake.
  4. Mar 5, 2011 at 3:44 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Because the engine air intake pulls air from the passenger side wheel well
  5. Mar 5, 2011 at 3:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My friends and I speculate that, being as the intake draws air from that fender, its to keep a high pressure area in that fender, useing the spinning tire. I dont have the means to actually test this however.
  6. Mar 5, 2011 at 3:46 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    turbo ventilation. gives you the added effect of a turbo even though you really don't have one.
  7. Mar 5, 2011 at 3:47 PM
    nrm
    nrm Well-Known Member
    NC
    2011 4.0 DCSB TRD Off-Road
    4-leaf TSB and Eibach 620 coils with Bilstein 5100's set to 0". AFE intake and Gibson cat-back exhaust. Bestop canvas topper
    Pretty sure it's just to be for "improved airflow" to the intake, since it's on that side right above the vent.
  8. Mar 5, 2011 at 3:48 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    You put your weed in there :D
  9. Mar 5, 2011 at 3:48 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Mine had them on both sides.
    +++234HP YO!!!
    jk:p
  10. Mar 5, 2011 at 3:54 PM
    toothaker1219
    toothaker1219 Well-Known Member
    As Chris said, Due to the spinning of the tire, it creates a "high pressure" channel of air that goes through the vents and gives cooler, cleaner air for the air intake. Also the air come from underneath the bumper.. Only way to really tell how much its doing is to set up an air velocity meter to the fender and calculate how much air is being driven through the vents and actually leading up into the fender.
  11. Mar 5, 2011 at 3:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The vents are used to cool the flux capacitor using the spinning tire. If you come to a stop, it will overheat and the truck will self destruct.:cool:
  12. Mar 5, 2011 at 4:01 PM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    Well chris when you come to Frederick MD. to help me lift my truck you can stand on my steps and hold on tight real tight and put your other hand near the tire to feel the air flow if there is any. lol
  13. Mar 5, 2011 at 4:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I......Im not sure I want to go that far....
  14. Mar 5, 2011 at 4:06 PM
    chugchug
    Will
    Frederick MD
    2012 Toyota Tundra
    As you wish just trying to help. Well really i just wanted help with the lift we can just you did it.
  15. Mar 5, 2011 at 5:17 PM
    chriss
    chriss Well-Known Member
    chris
    It is an additional vent for engine intake. The so-called CAI.
    However the spinning tire does not create any noticable "high pressure area" in the fender well.
    If you look at the the posted picture, you can actually see light through the vents. The inner fender well is open on the lower front for additional air flow. Most intakes draw air from an indirect stream. Yes, you want cool, high pressure air. No, you do not want a direct "ram" air stream. As this can carry a lot of dirt and debris with it. So by allowing the air to flow through and pulling the intake off that stream you get the cooler air without the heavier debris.
  16. Mar 5, 2011 at 7:39 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Speed holes.
  17. Mar 5, 2011 at 7:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This missing plastic on the passenger side is the obvious cause for the infamous " Taco lean "
  18. Mar 5, 2011 at 7:44 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    weight savings....better handling
