Whats the diagnosis and repair here?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrutalityBob, Feb 27, 2016.
  1. Feb 27, 2016 at 11:19 AM
    BrutalityBob
    BrutalityBob [OP] Well-Known Member
    This is the driver side and best guess is the leaks coming from the cracked boot, also recently been hearing this screech while coasting without hitting the gas which brought me to this discovery
  2. Feb 27, 2016 at 11:22 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    depending on mileage it might be time to replace the CV joint. If you go sharp left or right do you hear clicking/popping noise?
  3. Feb 27, 2016 at 11:23 AM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    Replace boot and cv joint.
  4. Feb 27, 2016 at 11:27 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Sometimes its easier to replace the CV joint than to replace the boot. Also, better, if you've been driving it for awhile with no lube. You can see that the boot is weathered in the photo. Must be an older truck. Up here in Canada, in the snow and ice where I live, driving through hard packed driveways where the snow plow stacks up the chunks of snow and ice can cause a ripped boot as well.
  5. Feb 27, 2016 at 11:28 AM
    BrutalityBob
    Ya where i live i got alot of roundabouts so can hear it then, and slow tight turns. Whats the damage at the autobody? Dont have much to work on it at my apartment and shes at 165k so thinking of doing some preventative maintanance while shes in the shop. Any suggestions on what to replace? Thanks all!
  6. Feb 27, 2016 at 11:30 AM
    BrutalityBob
    And yes colorados snowpack is pretty lethal or was a month ago. Was really giving here in the backcountry slush. Trucks an 05 by the way so might be worthwhile changing both sides.
