What's the diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomoMoto, Aug 3, 2011.
  1. Aug 3, 2011 at 8:04 AM
    TacomoMoto
    TacomoMoto [OP] Well-Known Member
    Miami
    09 SR5 Sport 6speed 4.0L
    What's the diff between the sport and the off road editions ?
  2. Aug 3, 2011 at 8:05 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    please use the search for this as it will go downhill very fast into a pissing match again.
  3. Aug 3, 2011 at 8:06 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Sport has a limited slip rear differential while the off-road has an electronic locking rear differential.
  4. Aug 3, 2011 at 8:07 AM
    jhodge83
    SC
    17 XLT Sport
  5. Aug 3, 2011 at 8:08 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  6. Aug 3, 2011 at 8:10 AM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
  7. Aug 3, 2011 at 8:11 AM
    jhodge83
    SC
    17 XLT Sport
    and this thread will self-destruct if it turns into said pissing match....
  8. Aug 3, 2011 at 8:11 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
  9. Aug 3, 2011 at 6:52 PM
    TacomoMoto
    Miami
    Ok so what are some of the better things on a sport VS the off road ? from what I've seen it sounds like the sport is a wannabe off road with a hood scoop ??
  10. Aug 3, 2011 at 7:44 PM
    JKD
    JKD Well-Known Member
    Primarily? The diff.
  11. Aug 3, 2011 at 8:31 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    If you plan on actually off roading, get the sport, as the diff will not self destruct.
    And do the yellow wire mod.
  12. Aug 3, 2011 at 8:33 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  13. Aug 3, 2011 at 8:34 PM
    OZ-T
    Peter North
    British Columbia
    ATRAC ATRAC ATRAC
  14. Aug 3, 2011 at 8:40 PM
    Isthatahemi
    TRD OFF ROAD
    Good for you. You treat it like a baby and drive like a girl.
    My first one was fine, till 18000kms, when it cratered.
    My second one was fine till I towed 9000kms, then it screamed.
    My third one was fine, till it got 20000kms of highway miles, by my wife, comuting. Then it sang a tune as well.
    Now I have #4, and the time bomb sound great!
    Lot's of failures on record by other folks. The difference is some of bought the truck with a locker to get us place the unlocked diff won't go. And I will never make excuses for using it.
    But I would rather a truck that get's stuck and doesn't break, vs a truck that breaks, because then I'm both stuck, and broken.
    Again, lots of other failures, anything less than an 8" ring on a 4500# truck is a bad joke. (Look at any other midsize.....)
  15. Aug 3, 2011 at 9:02 PM
    OZ-T
    Peter North
    British Columbia
    It's not a Hemi
  16. Aug 4, 2011 at 4:58 AM
    TacomoMoto
    Miami
    What's the yellow wire mod ?
  17. Aug 4, 2011 at 5:26 AM
    Pugga
    Massachusetts
    F-150 Mod
  18. Aug 4, 2011 at 1:36 PM
    TacomoMoto
    Miami
    Ok so it sounds like I made the better choice for what I'm gong to use the truck for thanks for all the info.. Still unclear on what the VSC does and if I have it on my truck .
  19. Aug 5, 2011 at 12:18 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
  20. Aug 5, 2011 at 9:06 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Not quite...
    unless you are speaking of 2005 to 2008 Sports Only.
    Toyota discontinued the mechanical limited slip rear differential... and now ALL Tacomas since 2009 have traction control (brake system limited slip) called TRAC and AUTO LSD in 2WD (with and without engine regulation)and TRAC in 4WD-HIGH (without engine regulation).
    This TRAC system provides limited slip on the front and rear axles in H2 and H4 (L4 is only open differentials, except the Off Road TRD).
    The non-Off Road Tacomas can do the 4-Lo trac mod (yellow wire mod) to get TRAC to work in L4.
    One thing no other Tacoma except the '09 + 4WD Off Road TRDs has is
    1) A-TRAC (creates the traction of front and rear lockers in low range) and
    2) the Hydraulic Brake Booster... this booster increases the power of the limited slip system to lock the rotation of a non-traction tire... it may also increase the traction in high range. Of course all Off Roads also have
    3) the rear locking differential.
    I am on my third Off Road 4WD Tacoma, and this one with A-TRAC is the greatest upgrade for off roading Toyota has ever made!
    Photos are available to see my truck in various off road situations... links below...
