whats the diff
Discussion in 'Suspension' started by Surreal Tacoma_08, May 27, 2008.
  1. May 27, 2008 at 10:49 PM
    Surreal Tacoma_08
    Surreal Tacoma_08 [OP] Wyotech 08
    utah
    08 taco 4x4 bone stock (for now)
    URD short shifter
    prerunner and just a normal taco 4x4 or is there any ?
  2. May 27, 2008 at 10:54 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    the difference is the pre-runner is two wheel drive with the ride height of a 4x4.
  3. May 28, 2008 at 4:30 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    5 lug = Taco with an I4 and 2wd. It sits very low to the ground.
    PreRunner = Taco 2wd, with I4 or V6 Engines, and has he same suspension and ground clearence of the 4x4.
    4x4 = Taco with the ability to power all for wheels
    X Runner = 5 Lug Taco with the V6 engine. Only available in access cab with a 6 speed manual, comes with a body kit and some good looking wheels.
  4. May 28, 2008 at 3:59 PM
    Surreal Tacoma_08
    utah
    URD short shifter
    thats pritty much what i though just whanted to check on the differences before i go and purchase anything! thanks for the help guys
  5. May 28, 2008 at 4:09 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    The term itself originated from the Baja racing circuit. Pre-Runners were, just as the name implies, trucks built to pre-run the course before the actual race. Pilot and navigator, or other team members, would take the pre-runner truck out to learn the course at a slightly more leisurely pace than they would be racing it for real. So basically WE PRERUNNERS run a circiut before them 4x4 guys get their toes wet:D
  6. May 28, 2008 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That is absoloutly correct! :thumbsup:
  7. May 28, 2008 at 4:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To be a little more accurate, A Prerunner is the same chasis and suspension of the 4x4. The only thing different is the lack of a transfer case, front diff. and front drive shafts. Oh, and the rear drive shaft is longer since there is no T case. FWIW, Even the spindles on a Prerunner are the same as a 4x4. They just have a cap on them since a front dive shaft is not going thru them. :)
  8. May 28, 2008 at 4:33 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    ..............:humble:..thanks Chris..:humble:
  9. May 28, 2008 at 5:11 PM
    Surreal Tacoma_08
    utah
    URD short shifter
    i know of the prerunners i have always been interested in the corr trucks and have always whanted to build a baja/dune rig...but thats another project!.........just wasnt sure if the prerunner taco had different spindles mount locations or what .....
    thanks for the info!
