Whats the difference between p rated and Lts?
Discussion in 'Wheels & Tires' started by Rob Lewis, Dec 4, 2008.
  1. Dec 4, 2008 at 8:08 PM
    Rob Lewis
    Rob Lewis [OP] Member
    Hippyville Oregon
    04 extracab 4x4 SR5 I4
    Are you guy's running P rated tires or Lts? The price for the Lts tires is as much as a set of BFG KO's! I'm talking about the Destination TA's!
    Help please!
    Rob
  2. Dec 4, 2008 at 9:31 PM
    dabighi
    dabighi Well-Known Member
    P= passenger car, lower load rating
    LT= light truck, higher load rating
    be safe and go with the lt's
  3. Dec 5, 2008 at 1:21 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    http://www.nittotire.com/assets/safety/Replacing%20Tires%20on%20Light%20Trucks.pdf
    I have Nitto Terra Grappler all terrain P rated 265/70/17 and no problems with them.
    My truck came with Dunlop Grandtrek at 20 P245/75/16 which are load rated at 2271lbs at 44PSI, but the sticker on the door says to have them at 29PSI which lowers the load rating even further.
    I now have Nitto's P rated tires with a load rating of 2535lbs @ 35PSI and I have them at 38PSI.
    So my P rated tires are safer than the stock tires.
    P rated tires are lighter which saves MPG, softer which provides a better ride and cheaper. They are fine for normal offroading, not rock crawling and extreme stuff.
  4. Dec 7, 2008 at 2:45 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    If you're a serious offroader or tow often, get LT's. Otherwise, you don't need them. I have the Destination A/T's and, since I rarely go offroad and don't tow anything, I got P265/75/16's. The LT's will definitely affect your MPG if that's any concern.
  5. Dec 7, 2008 at 7:39 PM
    Rob Lewis
    Hippyville Oregon
    Yeah I talked to a tire guy and all he said was "You don't need 10plys It will ride like a tank!" I rarely tow anything heavier than a drift boat so I think I should be ok with the P's! Thanks again all who took the time to answer!
    Rob
