What's the fuss over body lifts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLtaco, Jul 18, 2010.
  1. Jul 18, 2010 at 7:45 AM
    FLtaco
    FLtaco [OP] Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    I've herd only bad things about body lifts? I have 3 inch suspension lift and want more. Was looking at 6" lifts but can save a but load just adding 3" body lift. Why are they bad?
  2. Jul 18, 2010 at 7:52 AM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    I'm no pro, but I think the main thing is how they don't really help you out OR. I believe it messes real bad with your overall CG of the vehicle therefore making you more likely to roll over.
    Plus, I'm just not a fan of the look. But like I said, I'm no pro on the matter so I'll let the other guys chime in.
  3. Jul 18, 2010 at 7:52 AM
    ratm3245
    ratm3245 Well-Known Member
    SW. Illinois
    2010 Black Sand Pearl 4X4 DC/SB TRD Sport
    TRD Cat-Back, Weathertech Mats, Nfab light bar, PIAA 520 ATP Drivers, PIAA 520 Fogs, Weathertech Vent/Visors, Blendmount Escort Radar Detector, Kenwood DDX516 HU w/Bluetooth, Kenwood Kna-G610 Hideaway Garmin GPS Navigation System, Alpine S-Series in the doors, JL Stealthbox, JL J2 500.1 Amp, Alpine MRP-F300 Amp, Pro Comp 7098 17X8, 265/70R17 Duratracs, UWS Lowpro Tool Box, K&N 63 Series Intake, 50% Tint in front, Bajarack, AllPro Sliders
    the reason I don't care for them is alot of the hoosiers around my neck of the woods don't fill in the gap in the wheel wells and IMHO it just doesn't look good with the tunnel look under the bed.
  4. Jul 18, 2010 at 8:00 AM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    i ran a 3 inch body lift on my ranger for 3 years with no issues, and i wheeled that truck fairly hard, it is an inexpensive way to fit larger tires, thus increasing your clearance, the only parts i saw bad about it is the bed brackets felt flimsy so i was afraid to put too much in the bed , as well as the steering extension they gave me had some slack in it so i had to fab another piece to make it not fit well .. with that being said i would invest in billies instead of a body lift, same amount of lift for almost the same price , and a performance increase, you can't do that with a ranger, most things for those trucks are $3k+
  5. Jul 18, 2010 at 9:05 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    So there not all that horrible then? I agree on gap under bed I know they sell gaurds which I may invest in and as for rollover I was looking at wheel spacers to push wheels out a little bit and prevent rollover as much as possible. 200,000+ miles to that's alot. I'm at 135,000 now but I did alot of driving first two years I owned and bought it used with 70,000 but toyota is good for high milage vehicles thank god. What are billies also?
  6. Jul 18, 2010 at 9:25 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
  7. Jul 18, 2010 at 9:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The issue with body lifts on the Tacoma, is if you off road, they can pull thru the sheet metal. They dont have as much of a "Foot print" on the body as when the body is mounted directly to the frame, useing OEM mounts, and the sheet metal is thin.
  8. Jul 18, 2010 at 9:41 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    The biggest issue that I have seen it the crappy washers that the kits come with.
    this was a while ago, but it was a Performance accessories BL. They may have improved since this.
    The bolts pulled directly through the PA washers. there was a perfect Hex shaped hole in the washer. you can see where the body shifted and the puck is still attached to the frame
    I think if it used the much thicker factory washers, it would have been fine
    This was my buddies truck, he hit a patch of ice on I64 on Afton MT and hit the guard rail at 55 mph. That was a 2.5" Cornfed spacer and PA 3" body lift and 33s
    Justin
  9. Jul 18, 2010 at 9:57 AM
    bailerc
    Cody
    Fayetteville, NC
    16' MGM Limited
    mine on my ranger was a PA, seemed to have a bigger footprint after because i left the stock washers on top of the lift washers , also as per advice from someone on theragerstation i swapped the bolts for stronger ones , i think i payed 40.00 from some website
  10. Jul 18, 2010 at 11:02 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Now with the 5100s I couldn't combine with my three inch lift correct? And how hard are body lifts to install? Something I could do on my own? Or better to pay a shop?
  11. Jul 18, 2010 at 11:06 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    There is also an increase in leverage on the body mounts caused by the lift, it makes the mounts more likely to fail.
  12. Jul 18, 2010 at 11:12 AM
    JDMcQ
    Anytime you raise any part of the vehicle you raise the cg. A body lift may not cause as much of an affect on the cg because the drivetrain is not lifted as much.
  13. Jul 18, 2010 at 11:20 AM
    JDMcQ
    I would think that the threat of body mounts shearing off would offset the value of not raising the cg by a little bit though.
  14. Jul 18, 2010 at 12:10 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    im not anti bodylifts.i have used them for years.i dont offroad my stuck.my brother offroads his 96 dodge ram 2500 with 5"susp and 3"body with 37" boggers.i kills it offroad so bad that people wont get in with him. truck has almost 300K miles and never a problem ever
    edit: the pic of the totalled green 4runner with the body lift is scary. too lazy to look for it
  15. Jul 18, 2010 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt want to get into the shear loading on the bolts, but you are correct.
  16. Jul 18, 2010 at 12:24 PM
    paintdiddy
    shithead
    silver bullet
  17. Jul 18, 2010 at 12:25 PM
    JDMcQ
    I know I'm correct, I'm f'in brilliant dammit!
    :D
  18. Jul 18, 2010 at 12:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well.....I think "Brilliant" may be a stretch. How 'bout "Not that retarded"? :p
  19. Jul 18, 2010 at 12:29 PM
    JDMcQ
    I'll take it!
  20. Jul 18, 2010 at 12:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :woot:
