What's the going rate for Line-X these days?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JJ04TACO, Jan 24, 2019.
  1. Jan 24, 2019 at 2:54 PM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Got quoted $450-500 for a short bed. :annoyed:
    I seem to remember 300-350 not long ago?
  2. Jan 24, 2019 at 3:11 PM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    I paid about $600 for the line-x with UV protection so it will stay black.
    I got a bed mat for about $80 too.
    I recently put the plastic protector back on the tailgate when
    I was hauling a bunch of junk (including several cast iron
    sinks) to the dump... my previous hauling around of some logs and
    stuff slightly dented the front bed wall, easy to see when the light
    is right...
    -Mike
    Hamer95USA and GQ7227 like this.
  3. Jan 24, 2019 at 3:25 PM
    Shiki Shabazz
    Shiki Shabazz Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    I had my whole truck done with the premium, $2700
    GQ7227 likes this.
  4. Jan 24, 2019 at 9:54 PM
    1997tacomav6
    Denver
    Mine was like 600.00
    GQ7227 likes this.
  5. Jan 24, 2019 at 9:56 PM
    Glamisman
    Glamisman Well-Known Member
    if they have to sand blast the bed for proper adhesion it will be more.
  6. Jan 25, 2019 at 6:29 AM
    adamdsgn
    adamdsgn Well-Known Member
    Adam
    2003 Tacoma Double-Cab - TRD/4x4
    I paid around $400 locally a year or so ago. One of the best investments I've made to date.
    joe25rs likes this.
  7. Jan 25, 2019 at 10:13 AM
    Oomaxse
    Oomaxse Well-Known Member
    2003 Red Tacoma Stepside TRD
    Stock
    Was quoted $600 through email when I described to them it was a stepside. Theres their "premium" one for $750 he said.
    Looking to DIY it instead for less than $200.
  8. Jan 25, 2019 at 10:19 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  9. Jan 25, 2019 at 10:26 AM
    adamdsgn
    Adam
    It's an easy and straight forward process. I'm not sure I would expect it to hold up as long as a professional coating, but you could always reapply. I stripped the inside of my '85 4runner scuffed up the surface and used a DIY kit (2-3 gallons) I purchased from Autozone back in the day. I'm not sure it would have held up as well had I used the same process/product in the bed or a truck, but it worked great for my specific application.
  10. Jan 25, 2019 at 10:31 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Try a few different places, they are all independent and will quote you different prices based on their mood and how much work they have.
  11. Jan 25, 2019 at 10:36 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    $530 here in Tucson, regardless of bed size. And we only have 1 LineX shop in town.
    Jerry311SD likes this.
  12. Jan 27, 2019 at 8:07 AM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Can a product like this be used to liven up a pre existing rhino lining/line x, just to bring color back?
    I use to apply a 303 product for luster and UV protection, but I do not like getting that product on anything I throw in the bed.
  13. Jan 27, 2019 at 12:10 PM
    F250orelse
    F250orelse Well-Known Member
    Michael
    Arkansas
    2022 Tacoma double cab trd 4x4
    ome 886 springs-shocks suspension, bfg’s 285’s. Camburg uca
    Shop in town wants 499 for just the inside of the bed and 150 for rails. What a rip off, my full size F250 bed was 600. I’ll most likely get it done out of state somewhere.
  14. Jan 27, 2019 at 1:02 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Quoted $550 for over the rail.
    I said no thanks and did the Raptor liner. After all was done it costed me around $170? I also did over the rail and 1/2” down. I gained experience, saved money, and added another DIY to my truck.
    6362645B-7D39-4549-A49C-AFE60000BC10.jpg 40E0ABA7-6832-42C9-A86D-728FBEC31DF4.jpg
    joe25rs, GQ7227, FitzTaco84 and 6 others like this.
  15. Jan 29, 2019 at 12:32 AM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Looking at doing this myself. Any videos that you found particularly helpful?
  16. Jan 29, 2019 at 12:35 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Are those 01-04 fenders?
  17. Jan 29, 2019 at 10:52 AM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    I watched one of Upol official DIY video on YouTube. I also made a DIY thread on here. Just search for raptor liner on the 1st gen section.
    jeg0005[QUOTED] likes this.
  18. Jul 9, 2019 at 6:12 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    why would they need to sandblast the bed?
  19. Jul 9, 2019 at 6:15 PM
    tony2018
    tony2018 Well-Known Member
    Look good chief.
  20. Jul 9, 2019 at 6:36 PM
    1997tacomav6
    Denver
    No, they are the earlier fiberglass TRD flares 98-2000
    GQ7227 and Luv my yota like this.
