What's the height difference from back to front on a stock Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DestinTaco, Aug 8, 2011.
  1. Aug 8, 2011 at 2:45 PM
    DestinTaco
    DestinTaco [OP] Well-Known Member
    Destin, Fl
    2011 Silver PreRunner Off Road DC SB
    Challenger tube step, OME 884 Coil, 2" AAL, Weathertech vent visors
    I thought I heard someone say 2" but I'm not sure. Thanks.
  2. Aug 8, 2011 at 3:06 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    When I get done out of the shitter, I will measure it for ya! :cheers:
  3. Aug 8, 2011 at 3:07 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    I have 1" of rake after lift
  4. Aug 8, 2011 at 3:14 PM
    DestinTaco
    Destin, Fl
    I just want to know the difference before any lift.
  5. Aug 8, 2011 at 3:16 PM
    Superx2
    Joey
    Iowa
    this is the front center of my tire...
  6. Aug 8, 2011 at 3:18 PM
    Superx2
    Joey
    Iowa
    this is the rear center. hope it helps ya.
  7. Aug 8, 2011 at 3:24 PM
    DestinTaco
    Destin, Fl
    About an inch and a half I see. Thanks.
  8. Aug 8, 2011 at 3:25 PM
    jandrews
    '09 FourDubDee TRD OR
    Roughly 1" of rake.
    It looks like more when you measure because the rear fender wells are arched higher than the fronts...they are not the same shape.
    Measuring, you should get about 1.75" of difference.
  9. Aug 8, 2011 at 3:29 PM
    DestinTaco
    Destin, Fl
    Let me ask this. I currently have 884's with 1/4" top plate spacers on the front and 2" AAL in the back. If I took off the spacers and also took off the AAL's, do you think I would be nose high or would it be right at level?
  10. Aug 8, 2011 at 3:31 PM
    jandrews
    No idea, but trucks should have rakes.
  11. Aug 8, 2011 at 3:45 PM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    I have 34'' front and 36.5'' rear measured in the center of the wheel. I do have a bull bar on the front though so that might bring the front down a bit.
  12. Aug 8, 2011 at 3:48 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    To many things are going to be different to measure one truck and carry that over to all stock trucks. Age, accessories, times it's carried a load, amount of gas etc..
  13. Aug 8, 2011 at 5:28 PM
    wartowntaco
    wartowntaco Active Member
    Warner Robins, GA
    2010 4x4 Double Cab TRD Sport
    I had 1 1/2" front to back with 3000 miles on a 4x4 double cab short bed before my lift.
  14. Aug 8, 2011 at 5:55 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Mine had a 2" rake with TSB spring pack...
  15. Aug 8, 2011 at 5:58 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    US stock trucks = 1 1/2"
    Canadian stock trucks , US TSB trucks = 2"
  16. Aug 8, 2011 at 5:59 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    potato?
  17. Aug 8, 2011 at 6:02 PM
    OZ-T
    Peter North
    British Columbia
    You say poe-tae-to
    I say poe-ta-toe
    Let's call the whole thing off
  18. Aug 8, 2011 at 6:17 PM
    TheGreekIndian
    TheGreekIndian Well-Known Member
    take off your spare and watch your rear rise!!!
  19. Aug 8, 2011 at 6:36 PM
    TacoDawgs
    Not sure why my rear sits so much higher than everyone's. And I don't have the TSB springs.
  20. Aug 8, 2011 at 6:37 PM
    OZ-T
    Peter North
    British Columbia
    You buy it new or used ?
