What's the highest you've taken your RPMs and how did it feel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by basurf9, Aug 13, 2015.
  1. Aug 14, 2015 at 7:46 PM
    #41
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    In 4 cycle fashion?
    Usethe2nd likes this.
  2. Aug 14, 2015 at 7:48 PM
    #42
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I had three Integra GS-R's before I got into Taco's.
    DoorDing likes this.
  3. Aug 14, 2015 at 7:50 PM
    #43
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    I regularly go 3000-3500. Manual transmission FTW.
    Generally, though, I end up shifting under 4K. I honestly don't think I've ever gone over 4K.
  4. Aug 14, 2015 at 7:52 PM
    #44
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I always thought it would be cool if they did.
    Justinlhc likes this.
  5. Aug 14, 2015 at 9:47 PM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Let me clarify what I said because it can be misconstrued. Raising the rpm limit increases the inertial loads with the square of the rpm increase.
    To be honest, I never weighed the Carrillo rods. There might have been a data sheet, but I don't remember if there was or if I took a picture. I will check though. Point is though, the weight is not my concern respective to the strength that they offer. The Carrillo rods are rated for 367 hp per-hole. Any type of response in instant performace will be negated by my sheer delight in strength and durability. ;)
    Is there a potential to make the response less? Obviously, if they weigh more. The pistons are also larger and weigh more, due to size, structural reinforcement, and much thicker wrist pins. Approximiately 1/4" wrist pins. The fight against deformation from boost pressures, timing, and increased rpm are my goals. However.....if I wanted to fork up the extra coin, I could have the strength with the light weight of titanium. Buuuuut, with what I've got, and the purpose of my build, titanium wasn't a necessity. As it is for other builds. That is the epitome of having your cake and eating it to.
  6. Aug 26, 2015 at 3:00 PM
    #46
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Urd u-conn.programer lets you when they program it to what you want.Mine is set at 7200rpm. Pulls like a freight train tranny doesn't like it automatic.
  7. Aug 26, 2015 at 3:46 PM
    #47
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Banged into the speed limiter on the '15. 110 on the Tacoma, 115 for 2nd gen Tundras. Think it was 110 on the 1st gens also.
