What's the lift limit before vibes hit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoopDog421, Jul 22, 2017.
  1. Jul 22, 2017 at 7:48 AM
    CoopDog421
    CoopDog421 [OP] Member
    2015 Tacoma TSS
    hey TW,
    Been lurking here since I bought my 15 dcsb 4x4 in Jan. It's a SR5, has the TSS wheels. I 'need' a lift and maybe larger tires (currently has 265/65/17 on them)
    So the question, has anybody figured out what the lift limit is to avoid drivetrain vibes after lifting? I just bought 5100's and I'm thinking of the 1.75 notch but want to avoid problems.
    Thanks
  2. Jul 22, 2017 at 7:52 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I'm at 2.5" on the same shocks and stock springs with 1.5" AAL in the rear, no vibrations here.
  3. Jul 22, 2017 at 8:08 AM
    Steevoreeno
    Steevoreeno Well-Known Member
    Merrimack Valley, MA
    2015 Access Cab TRD Off-road
    2015 TRD OR Access Cab
    5100's at 1.75 with TRD Sport coils.
    Wheelers AAL 1.5 pack in the rear.
    Installed above with only 20k miles on truck.
    Instant needle bearing rumble/vibe.
    My dealer replaced it under warranty yesterday, but I'm going to go ahead and buy the parts for the ECGS bushing upgrade in case it comes back.
    FYI, I've read that owners with completely stock trucks have encountered the needle bearing transfer case problem.
  4. Jul 22, 2017 at 8:48 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    There is no definitive answer. It's different for every truck. I had mine @ .85" for years, and had no issues until I added a 1/4" spacer.
    The best answer you'll get, is if you lift be prepared for driveline issues. If you don't get any, consider it a bonus. If you do, there are many that have been through it already, and can point you to the proper fix.
    JoefromPTC likes this.
  5. Jul 22, 2017 at 9:52 AM
    CoopDog421
    2015 Tacoma TSS
    I just have a hard time understanding that the vibes are so random. So I don't have any vibes now, with 26k. I would think Toyota has figured out what fails or needs modification by now.
  6. Jul 22, 2017 at 9:55 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    If they cared, they would fix the needle bearing issue that started in 2005 (among other issues). Instead, they carried it over to the third gens. They care about dollars, not you. My 2015 had needle bearing vibe issues from when I picked it up with 6 miles on it. They told me "that's how they all drive".
    My needle bearing was improperly installed from the factory... Maybe the reason i had the vibes at stock height.
  7. Jul 22, 2017 at 10:43 AM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I had 5100s at 1.75 on my truck for about 60k miles, no issues, now I have new 5100s with OME 885 coils and an AAL in the rear, 126k on the truck, no issues.
  8. Jul 22, 2017 at 10:45 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    The limit is anything above stock. Any lift can trigger vibes. Whether due to bad driveline angles or the front diff needle bearing.
    It's all,about proper install and shimming if needed. Then replacing the front needle bearing with the ECGS bushing.
    I did a 3" suspension lift. Front needle bearing began vibrating immediately. However, since my OME kit from @HeadStrong Off-Road came with all the necessary stuff my driveline angles were damn near perfect (so says a local driveline shop).
  9. Jul 22, 2017 at 10:50 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    I have a TRD Pro and an ICON progressive AAL on the rear. Sits level roughly 2" all around. That's very mild by the standards of the owners on TW, but it looks good, and has no vibes.
  10. Jul 22, 2017 at 11:03 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I had the needle bearing vibrations on 2013 DCLB Sport. Fixed it last week with the ECGS bushing. My suspension is stock. Looking to do lift this fall.
