What's the longest you've gone on a timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Mar 27, 2017.
  1. Mar 27, 2017 at 12:42 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    My timing belt was replaced at 65k miles and I'm currently at 175k. I'm planning on stretching it to 200k because I also want to get the valves checked, injectors serviced and valve cover gaskets replaced all at once. That will mean my TB will have 135k on it before being replaced. I live in TN so not a lot of harsh exposure to the elements.
    How long have you gone on a single timing belt/water pump?
    2002Tacoma4x4 and GQ7227 like this.
  2. Mar 27, 2017 at 12:58 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    A buddy of mine about 10 years ago ran his to ~235,000 on the original timing belt. He said it broke pulling into work one day so he had a shop come pick it up and they had it ready by the time he got out that afternoon. I've always thought the recommended 90k interval was excessive. I think 150k is good time to replace. That just my $.02 so take it FWIW.
    2002Tacoma4x4, GQ7227 and keakar like this.
  3. Mar 27, 2017 at 1:12 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Went 120k on mine...didn't break.
    2002Tacoma4x4 likes this.
  4. Mar 27, 2017 at 1:38 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    About 10,000 miles... Hopefully this one will get to stay on the truck a little longer.
    GQ7227 and FirstTimeFirstGen like this.
  5. Mar 27, 2017 at 1:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I went 220k on my last Tacoma. Frame broke, so I don't know how much further it would have gone.
  6. Mar 27, 2017 at 5:46 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    My original timing belt went 206,000. New one has 30k on it.
  7. Mar 27, 2017 at 8:04 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    110k on mine, still looked fine when it was replaced. Probably could've gone another 50k but it's one of those things you never know until you take it all apart.
  8. Mar 28, 2017 at 6:04 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Went 196k on the original and was still in decent shape too
  9. Apr 5, 2017 at 7:41 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks guys, making me feel better about putting it off.
    GQ7227 and 2002Tacoma4x4 like this.
  10. Apr 6, 2017 at 2:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Not sure if mine was ever replaced I bought the truck at 125,000 now at 223,000 .
    I know for sure 98,000 miles .
    When I bought the truck I pulled the Top cover things looked good been driving every since
  11. Apr 6, 2017 at 2:35 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    close to 115k miles on a 03 and did not look that bad when it was changed.
  12. Apr 6, 2017 at 12:56 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    180k. Got about 400 miles on the new one
  13. Apr 6, 2017 at 1:40 PM
    bretts
    bretts Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    On the 97 we had it was replaced at 200k and we sold the truck at 350k on the 2nd belt so I'd say at least 150k miles is expected... This was a truck that saw 100-150 miles per day and made many trips across the us, though. so many many highway miles.
    GQ7227 likes this.
  14. Apr 7, 2017 at 7:26 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    Replaced at 196k . Timing belt was cracked, and waterpump was leaking.
    218k now.
    2002Tacoma4x4 and boostedka like this.
  15. Apr 7, 2017 at 7:28 PM
    boostedka
    James
    NM
    That's pretty helpful info! That in conjunction with what a lot of other people have said gives a good range of mileage for changes. I don't even have a 3.4 and I'm happy you shared this :thumbsup:
  16. Apr 7, 2017 at 11:35 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I recently did a timing belt on a 97 camry v6 that was original with 340k on it... Water pump locked up and shreded the belt. honestly ive never seen a belt break unless it was something locked up.
    had 150k on my last one. it was cracked up pretty good. only replaced it due to the water pump leaking.
  17. Apr 8, 2017 at 9:04 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I think with most factory recommendations on replacing things, they add a cushion on the side of being overly cautious with estimates, with this in mind I view things like timing belts and tranny flushes can "usually" go reliably double what they say.
    since the factory says 90k is recommended, I take that to mean it should last 180-200k miles.
    that said, driving style and habits as well as weather conditions play a part in how long it lasts
  18. Jul 26, 2019 at 4:36 PM
    jmpadil3
    jmpadil3 New Member
    236k on my 2001 4 cyl. single cab and haven't had any problems. Perhaps I should look into doing this soon as a precaution.
  19. Jul 26, 2019 at 4:42 PM
    koditten
    Kirk
    Central Michigan
    4 cylinders have timing chains. They don't need replaced. You got plenty to go.
    Currygoat and GQ7227 like this.
  20. Jul 26, 2019 at 4:46 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I've done 100K on the Tacoma but on civics, I've replaced them between 120K-150K and it still looked good. I'd say 125K would be the most I'd go before replacement just to be on the safe side.
