What's the max someone has towed with a 2016 V6?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TTUJAY, Nov 17, 2017.
  1. Nov 17, 2017 at 12:58 PM
    TTUJAY
    TTUJAY [OP] Member
    Jason Vaughn
    2017 Tacoma Limited
  2. Nov 17, 2017 at 1:00 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Cant say with a 3rd gen but i towed a 23ft 5300lb boat with a 1st gen for about 60 miles. And towed a 30ft 9800lb boat for about 17 miles with my 2nd gen. V6 in both. They did fine
    TTUJAY[OP] likes this.
  3. Nov 17, 2017 at 1:02 PM
    TTUJAY
    TTUJAY [OP] Member
    Jason Vaughn
    2017 Tacoma Limited
    Wonderful! I just purchased an RV that is 3800LBS (dry weight) and was concerned.
  4. Nov 17, 2017 at 1:03 PM
    757yotas
    Virginia
    2007 TRD Sport
    Oh you will be 100% fine dont worry about something that light. These trucks are severely underrated by toyota i think
  5. Nov 17, 2017 at 1:03 PM
    Taco16LB
    Taco16LB Well-Known Member
    What is the point ? When I was a teenager , my buddy and I towed a 4500# fiberglass boat with a Datsun B210 car for a few years of fishing . Comical but it worked .
    synaps3 and TTUJAY[OP] like this.
  6. Nov 17, 2017 at 1:06 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
  7. Nov 17, 2017 at 1:08 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    over 9000
    Comb, J.M Taco, Bascoma and 1 other person like this.
  8. Nov 17, 2017 at 1:09 PM
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    A couple weeks ago I towed a 12' x6' U-Haul box trailer loaded with 2000lbs of weight over 2 mountains and up 10km of a pretty rough logging road. total weight was a little over 4000lbs. My 17 DCSB OR did just peachy! It wasn't till I tried to back up a 200m paved driveway, at a 20° incline, that I had issues. Although I think the weight was closer to 5000 at that point.
    Paul631 and TTUJAY[QUOTED][OP] like this.
  9. Nov 17, 2017 at 2:15 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    most you should ever tow is 6800 lbs if you have the tow package
  10. Nov 17, 2017 at 3:04 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Depending on model and options. Check your owners manual as this is the highest rating I believe for a 3rd gen. I know my OR is rated for 6500lbs.
    I don’t get questions like “what is the max someone has towed”. The truck is rated at a certain weight as well as tongue weight. Exceeding these numbers may void your warrantee if there is structural damage and may make you liable in the case of an accident. In the case of an accident you may be found responsible for financial damages and if injury or death is a result you may be found criminally responsible resulting in jail time.
    Simpleton[QUOTED] likes this.
  11. Nov 17, 2017 at 4:33 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Removed and transported about 800 square feet of tile, grout and cement board. Not sure how much it weighs, but it brought bed down to the max. Left it for 12 hours then took it to work, then a dumpster. Everything turned out fine.
  12. Nov 18, 2017 at 12:44 PM
    justintackitt
    justintackitt Well-Known Member
    2016 Tacoma DCTRD4X4
    16’ food trailer. 6000+ pounds with 800+ pounds on the tongue depending on propane and fresh water tank levels. Timbren system, e load 265/75/16 and trailer brake system and it handles the weight very well. The look on the trailer builders eyes was priceless when I unloaded all 800 pounds onto the tongue and the truck squated maybe 3/4 inch. The timbren system is incredible. Average 10 mpg when towing isn’t all that bad in my opinion.
