Whats the max travel ?
Discussion in 'Suspension' started by Penten, Oct 8, 2014.
  1. Oct 8, 2014 at 10:41 AM
    Penten
    Penten [OP] Well-Known Member
    Peter
    Iowa
    So guys I have a 97 V6 SR5 4x4
    So I was wondering what the max length of coilovers and shocks I can fit under is.
    Here's my setup that I was thinking of running
    Leaf Pack WHEELER’S 1995-1997 TACOMA 4×4 AND PRERUNNER 8 LEAF REAR LEAF SPRING SET
    -Shackles WHEELER’S STOCK HEIGHT HD GREASABLE SHACKLE SET
    -Rear shocks KING smoothie
    -Coilovers (Mid-travel) KING MID-Travel COILOVER
    -UCA Ball joint Light Racing
    -Extended brake lines Whatever + BPV relocate
    -BAMF shock relocation
    I want this to be a Mid travel/Expo/Camping rig
    Thanks for any help guy !
  2. Oct 8, 2014 at 10:42 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Running Coilovers like the Kings, or Icons with some Uni-Ball UCAs will provide the max safe travel for the front suspension.
  3. Oct 8, 2014 at 10:49 AM
    Penten
    Peter
    Iowa
    Living in the Mid west I hear that maintenance can be a real pain so that's why I decided to use a ball joint
  4. Oct 8, 2014 at 10:53 AM
    Large
    Large Red
    If you call the guy above you and tell him how you want to wheel and what you are trying to achieve he will set you in the right direction.
  5. Oct 8, 2014 at 11:26 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The Camburg BJ UCAs are much stronger if you are going to be wheeling it. They re-angle the cup so that the joint is more in it's center range of motion for lifted applications.
  6. Oct 8, 2014 at 11:57 AM
    Penten
    Peter
    Iowa
    I tried finding them , never found some for a 97 however :confused:
  7. Oct 8, 2014 at 12:04 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Oops... Sorry, forgot yours was a 97. They don't have any for that gen.
  8. Oct 8, 2014 at 12:29 PM
    Penten
    Peter
    Iowa
    So as far as size of coilover and shock what size are you guys thinking I need to be concerned about the collapsed length correct?
  9. Oct 8, 2014 at 12:34 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Not really. Your factory bumpstops will stop the suspension before any of the coilovers will bottom out.
  10. Oct 8, 2014 at 3:40 PM
    Penten
    Peter
    Iowa
    Yeah I was planning on getting new bump stops. I guess I'm just worries about the space between the lca and top mount I should probably just measure it
  11. Oct 10, 2014 at 9:30 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    I have the LR UCAS and king mid travel coilovers. No issues for over 6 months and I have wheeled it pretty good. I also have a 97 but a reg cab 4 cyl.
  12. Oct 11, 2014 at 5:39 PM
    Penten
    Peter
    Iowa
    Cool thanks man 10" travel ?
  13. Oct 12, 2014 at 4:03 AM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    If I remember correct the mid travel only adds 1" over stock travel. Any more and you need new axles, etc.
