Whats the most comfortable ride when leveling truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hockeydad, Jun 7, 2011.
  1. Jun 7, 2011 at 9:23 PM
    Hockeydad
    Hockeydad [OP] Member
    So Cal.
    11 TRD Off Road Prerunner
    5100's and tint so far.
    Does anyone know which way is the smoothest ride bilstein 5100s with stock springs or eibach or ome 1.5 lift springs with stock bilsteins.
  2. Jun 7, 2011 at 9:29 PM
    Hockeydad
    So Cal.
    But that will only lift it .8" im trying to get 1.5" to level the truck.
  3. Jun 7, 2011 at 9:38 PM
    Hockeydad
    So Cal.
    Im sorry i was replying to whippersnappers reply but thanks for the info everyone.
  4. Jun 7, 2011 at 9:44 PM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
  5. Jun 7, 2011 at 9:49 PM
    Hockeydad
    So Cal.
    Thanks Idaho but i just want to level truck not lift rear too.
  6. Jun 7, 2011 at 9:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The rear billies provide no lift
  7. Jun 7, 2011 at 10:13 PM
    Hockeydad
    So Cal.
    Wolfpack are your 5100s set at .8 or 1.75
  8. Jun 8, 2011 at 5:35 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Well, I dont have personal experience w/ either setup, but, I would imagine that a compressed progressive spring has the chance of being stiffer than a linear spring (uncompressed) depending on the linear spring's rate. Additionally, it would depend on the amount you're compressing the stock springs since the more you compress a progressive rate spring, the stiffer it gets (duh). SO, if you compress the stock springs past what the linears are rated at, the stockers will be more unforgiving. Compress it less than the linears, and it'll be more plush over the small stuff, while harsher on the bigger hits.
    I know that doesnt narrow down the answer, but imo, too many variables.
